Copy By DateLastModified
robostudent
Post by robostudent »
Hi all,
I have been working with the interface for about a week, but I still
dont understand some of the functions. Im trying to copy file(s) by ext
and the DateLastModifed - I can see the "search files" function and I
input the dates I want - it makes the txt file perfectly, but the
"File/Copy/Move" fucntion does not have a date option. How do you tie
the two together? Also I notice many people post request and have
script examples how do they do that.???
You can make the list of files and, next, copy listed files. See task below.
Save text of task into any file and use menu “Task | Import” to import into RoboTask
;* RoboTask Task file *
;* Do not edit!       *
CatID=INTEGER|850444931
ExternalName=STRING|"Task270"
ID=INTEGER|705095560
Name=STRING|"Create File List and copy"
Name=STRING|"Create File List (c:\tempfiles.txt)"
After=STRING|"0"
aftercount=STRING|"0"
AfterLine=STRING|"0"
Before=STRING|"0"
beforecount=STRING|"0"
BeforeLine=STRING|"0"
createmode=STRING|"5"
createormodified=STRING|"1"
date1=STRING|"20050615"
date2=STRING|"20050615"
destfile=STRING|"c:\tempfiles.txt"
file0=STRING|"{TempDir}\*.*"
OlderDays=STRING|"5"
subdirs=STRING|"1"
Name=STRING|"Text Loop"
destvar=STRING|"C_FILE"
file=STRING|"C:\tempfiles.txt"
linecount=STRING|"0"
sourcetext=STRING|"0"
ActionID=STRING|"A_FILE_COPY"
Name=STRING|"Copy/Move File"
destdir=STRING|"C:\Temp"
f_count=STRING|"1"
file0=STRING|"{c_file}"
ifexists=STRING|"0"
move=STRING|"0"
subdir=STRING|"0"
