XML
petlove
XML
Post by petlove »
Hello guys,
I am looking for solution of this. Thank you in advance.
I use Save XML to make a XML-file.
From this I want to make the XML
<voorraad><item><artikel>POST</artikel><aantal>-4</aantal></item><item><artikel>RING N&S</artikel><aantal>0</aantal></item><item><artikel>SC1911-117</artikel><aantal>0</aantal></item><item><artikel>SC1911-330</artikel><aantal>0</aantal></item></voorraad>
But each time there is an error: It is (I'll think) because off the & sign
How to solve this??
In the help file is the following: Automatically converts non-ASCII symbols into the UTF8 format.
When I skip the
part the XML is made correct
Is there another way to do this?
Re: XML
Because symbol & (ampersand) is reserved symbol for XML format.
This symbol means that you use some special symbol like in HTML format
Look here about special symbols for HTML & XML format: https://www.ascii.cl/htmlcodes.htm
You have to use such expressions instead of ampersand char:
-or-
The expression below is correct:
Also look at my small example
CatID=INTEGER|1360203151
ExternalName=STRING|"Task46"
ID=INTEGER|1800145511
Name=STRING|"XML node with special char"
ActionID=STRING|"A_XML_CREATENODE"
Name=STRING|"XML Create Node ""nod"" and save to ""xml"""
attcount=STRING|"0"
name=STRING|"nod"
txt00000000=STRING|"RING N&S"
txtcount=STRING|"1"
variable=STRING|"xml"
Name=STRING|"Show ""{xml}"""
msg0=STRING|"{xml}"
petlove
Re: XML
Post by petlove »
Thank you!
Blackjack
Re: XML
Post by Blackjack »
Great!Thank you!
