move one at a time
sen5241
move one at a time
Post by sen5241 »
Hi
is it possible to count al files in a folder ?
Then 1 after an other move them to a different folder (but only when it is completely empty, so there can only be one file at a time in this folder)
I will move this files my self. Then when when this folder is empty again, move the next to this different folder?
regard richard
move one at a time
See task below. This task calculates number of files and total size in specified folder.
;* RoboTask Task file *
;* Do not edit!       *
CatID=INTEGER|840229289
ExternalName=STRING|"Task31"
ID=INTEGER|501984439
Name=STRING|"Folder Info Demo"
ToLog=INTEGER|2
Action14=FOLDER
Action15=FOLDER
Action16=FOLDER
Action17=FOLDER
Action18=FOLDER
Action19=FOLDER
ActionID=STRING|"A_ROBOTASK_MINIMIZE"
Name=STRING|"Minimize RoboTask"
Name=STRING|"Increment variable ""F_Count"""
incement=STRING|"1"
vaiable=STRING|"F_Count"
Name=STRING|"Increment variable ""Total_Size"""
incement=STRING|"{FileSize}"
vaiable=STRING|"Total_Size"
Name=STRING|"Show ""Folder ""{SELECTEDFOLDER}"" contains {F_COUNT} files."""
[Actions\Action13\Params]
msg0=STRING|"Folder ""{SELECTEDFOLDER}"" contains {F_COUNT} files."
msg1=STRING|"Total size is {TOTAL_SIZE} bytes"
msgcount=STRING|"2"
[Actions\Action14]
[Actions\Action15]
ActionID=STRING|"A_ROBOTASK_RESTORE"
Name=STRING|"Restore RoboTask"
[Actions\Action16]
Name=STRING|"Remove variable ""F_COUNT"""
[Actions\Action16\Params]
varname=STRING|"F_COUNT"
[Actions\Action17]
Name=STRING|"Remove variable ""TOTAL_SIZE"""
[Actions\Action17\Params]
varname=STRING|"TOTAL_SIZE"
[Actions\Action18]
Name=STRING|"Remove variable ""FLENAME"""
[Actions\Action18\Params]
varname=STRING|"FLENAME"
[Actions\Action19]
Name=STRING|"Remove variable ""FILESIZE"""
[Actions\Action19\Params]
varname=STRING|"FILESIZE"
Name=STRING|"Show ""This task calculates number of files and """
msg0=STRING|"This task calculates number of files and "
msg1=STRING|"total size of specified folder."
msgcount=STRING|"2"
caption=STRING|"Select Folder"
default=STRING|"None"
folder=STRING|"{TempDir}"
variable=STRING|"SELECTEDFOLDER"
value1=STRING|"{SELECTEDFOLDER}"
value2=STRING|"None"
msg1=STRING|"No Folder is Selected"
msgcount=STRING|"2"
ActionID=STRING|"A_FLOW_ELSE"
Name=STRING|"Else"
Name=STRING|"Set varible ""F_COUNT"" with value ""0"""
varvalue=STRING|"0"
Name=STRING|"Set varible ""TOTAL_SIZE"" with value ""0"""
varvalue=STRING|"0"
Name=STRING|"File Loop"
date1=STRING|"20040323"
date2=STRING|"20040323"
destvar=STRING|"FILENAME"
file0=STRING|"{SELECTEDFOLDER}\*.*"
savesize=STRING|"1"
savevar=STRING|"FILESIZE"
subdirs=STRING|"1"
timesize=STRING|"0"
sen5241
move one at a time
Post by sen5241 »
hi oleg
i made this myself
this is perfect for me and i made it for the example "find latest/newest modified file"
the only problem is  it only works with the newest files and i want the oldest files first
if you got the time take a look at this
file structuur is D:\robotask\recieve and D:\robotask\teller
and it only works with *.mov
THANKS  richard
;* Do not edit!       *
CatID=INTEGER|0
ExternalName=STRING|"Task3"
ID=INTEGER|1043014426
Name=STRING|"nieuwste file in folder"
Action14=FOLDER
Action15=FOLDER
Action16=FOLDER
Action17=FOLDER
Action18=FOLDER
Action19=FOLDER
Action20=FOLDER
operator=STRING|"1"
value1=STRING|"{FileExists(D:\robotask\teller\*.mov)}"
Name=STRING|"Set variable ""LATEST_DATETIME"" with value ""{CURRENT_DATETIME}"""
varname=STRING|"LATEST_DATETIME"
varvalue=STRING|"{CURRENT_DATETIME}"
ActionID=STRING|"A_FILE_COPY"
Name=STRING|"Copy/Move File"
destdir=STRING|"D:\robotask\teller"
f_count=STRING|"1"
file0=STRING|"{LATEST_FILENAME}"
ifexists=STRING|"1"
move=STRING|"1"
subdir=STRING|"0"
[Actions\Action14]
Name=STRING|"Show ""Folder: RECIEVE"""
[Actions\Action14\Params]
msg0=STRING|"Folder: RECIEVE"
msg1=STRING|"Latest file: {LATEST_FILENAME}"
msg2=STRING|"Modified: {LATEST_DATETIME}"
msgcount=STRING|"3"
[Actions\Action15]
Name=STRING|"Remove variable ""CURRENT_FOLDER"""
[Actions\Action15\Params]
varname=STRING|"CURRENT_FOLDER"
[Actions\Action16]
Name=STRING|"Remove variable ""CURRENT_FILE"""
varname=STRING|"CURRENT_FILE"
[Actions\Action17]
Name=STRING|"Remove variable ""LATEST_DATETIME"""
[Actions\Action18]
Name=STRING|"Remove variable ""LATEST_FILENAME"""
varname=STRING|"LATEST_FILENAME"
[Actions\Action19]
Name=STRING|"Break"
Name=STRING|"Create variable ""LATEST_FILENAME"" with value ""Not Found"""
varvalue=STRING|"Not Found"
[Actions\Action20]
Name=STRING|"Create variable ""LATEST_DATETIME"" with value ""0"""
varvalue=STRING|"0"
date1=STRING|"20040520"
date2=STRING|"20040520"
destvar=STRING|"CURRENT_FILENAME"
file0=STRING|"D:\robotask\recieve\*.mov"
subdirs=STRING|"1"
timesize=STRING|"1"
timevar=STRING|"CURRENT_DATETIME"
message=STRING|"Current DateTime {CURRENT_DATETIME}"
message=STRING|"Latest DateTime {LATEST_DATETIME}"
operator=STRING|"3"
type=STRING|"2"
value1=STRING|"{CURRENT_DATETIME}"
value2=STRING|"{LATEST_DATETIME}"
message=STRING|"CURRENT_DATETIME {CURRENT_DATETIME} > LATEST_DATETIME {LATEST_DATETIME}"
Name=STRING|"Set variable ""LATEST_FILENAME"" with value ""{CURRENT_FILENAME}"""
varvalue=STRING|"{CURRENT_FILENAME}"
id=STRING|"IV17E3HT"
interval=STRING|"10"
move one at a time
In order to find oldest file you must modify your task so:
1. Insert this construction after "File loop" action
   If Latest_DateTime = "0" then
      Set variable "LATEST_FILENAME" with value "{CURRENT_FILENAME}"
      Set variable "LATEST_DATETIME" with value "{CURRENT_DATETIME}"
   end if
2. In If then action chande "> More" to "< Less"
And everything must work fine.
move one at a time
What for is placed Break at the end of your task ?
sen5241
move one at a time
Post by sen5241 »
hi oleg
the break is a mistake
can you also show me the change ik al task???
richard
sen5241
move one at a time
Post by sen5241 »
i got i !!!!!!!!!!!
thanks
richard
sen5241
move one at a time
Post by sen5241 »
sen5241 wrote: i got it !!!!!!!!!!!
thanks
richard
