SCP config files off Netscalers
kevins
Post by kevins »
Can robotask do SCP to copy the config files off of my Netscalers? They are Linux devices.
-Thanks,
Kevin
Re: SCP config files off Netscalers
RoboTask doesn't support secure copy protocol (SCP) directly now
I wrote this into out ToDo. Probably we'll add this feature later.
RoboTask supports only sFTP (ssh FTP) from SSH family now.
You can use PSCP.EXE free open source utility.
PSCP.EXE utility is the part of PUTTY package. You can find all necessary files here
Example of command line:
PSCP.EXE -scp -pw <password> <username>@<remotehost>:<remotefile> <localfolder>
Also you can copy local file to remote host. Read about all command-line options here
You can use Run Program/Open Document or Run Command-Line Utility actions to use command line.
