Choice Dialog with variables
pancakegh
Post by pancakegh »
Is there by any chance the possibility to load a text file (with sepperate lines) into a choice dialog?
Say there are .jpg files in a folder called "test".
We first run the task and input a search string, lets take "cool" as example.
The task wil then search for .jpg files and list their paths in a .txt file called "searchresults.txt".
Then I want to list all the search results in a choice dialog, which in turn will open the selected .jpg file.
Re: Choice Dialog with variables
This feature will be in next release.
Coming soon
