Add New Trigger Please
WellWisher
Post by WellWisher »
Very good update, especially action "FIND AN ELEMENT BY IMAGE", but I would like to have such a TRIGGER.
Re: Add New Trigger Please
I'm afraid that such trigger can load processor permanently
I wrote this into or ToDo. Maybe it's possible to optimize something
But pay attention that you can make something right now.
You can check the existence of element by using Find an Element by Image action
Go to Additional parameters tab and uncheck "Generate error... " checkbox and check Save True or False to variable
algorithm of the task will be so:
If {found} = true then
   Start another task
end if
Attach to this task Cyclic trigger. Suppose every 3 seconds.
This construction will work as trigger you want.
WellWisher
This is a good idea, but then the action "Find an Element by image" should have the option not to move the mouse to this object.
OK, wrote into our ToDo
marcolobaido
Post by marcolobaido »
Hi I would like to propose to add a tolerance range to the action "find by image". Sometimes it doesn't find the image (a java based software's button) and I think that this could be solved introducing a percentage of matching pixels. What do you think?
