Backup your tasks
Re: Backup your tasks
I added one step to the task (see step #15)
Try this. It allows to find problem folder.
CatID=INTEGER|1163085779
ExternalName=STRING|"Task17"
ID=INTEGER|913310745
Name=STRING|"[DEMO] Backup your tasks (daily backup) (imported)"
Action14=FOLDER
Action15=FOLDER
Action16=FOLDER
Action17=FOLDER
Action18=FOLDER
Name=STRING|"Create local variable ""BACKUPFOLDER"" with value ""c:\auto\RoboTaskBackup"""
varname=STRING|"BACKUPFOLDER"
varvalue=STRING|"c:\auto\RoboTaskBackup"
Name=STRING|"Create local variable ""OLDFOLDER"" with value """""
varname=STRING|"OLDFOLDER"
Name=STRING|"Create local variable ""CNT"" with value ""0"""
varname=STRING|"CNT"
varvalue=STRING|"0"
Name=STRING|"File Loop"
[Actions\Action12\Params]
date1=STRING|"20130328"
date2=STRING|"20130328"
destvar=STRING|"OLDFOLDER"
DuringMinutes=STRING|"1"
file0=STRING|"{BackupFolder}\*.*"
searchkind=STRING|"1"
sort=STRING|"1"
sortby=STRING|"0"
sortorder=STRING|"1"
subdirs=STRING|"1"
timesize=STRING|"0"
Name=STRING|"Increment variable ""cnt"""
[Actions\Action13\Params]
incement=STRING|"1"
vaiable=STRING|"cnt"
[Actions\Action14]
[Actions\Action14\Params]
operator=STRING|"3"
type=STRING|"1"
value1=STRING|"{Cnt}"
value2=STRING|"{BackupDays}"
[Actions\Action15]
[Actions\Action15\Params]
message=STRING|"Removing {oldFolder}"
[Actions\Action16]
Name=STRING|"Remove Nonempty Folder  ({OldFolder})"
[Actions\Action16\Params]
deletefolder=STRING|"1"
folder=STRING|"{OldFolder}"
[Actions\Action17]
[Actions\Action18]
Name=STRING|"Create local variable ""TODAYFOLDER"" with value ""{BackupFolder}\{Year}{MonthNo}{Day}"""
varname=STRING|"TODAYFOLDER"
varvalue=STRING|"{BackupFolder}\{Year}{MonthNo}{Day}"
Name=STRING|"Create local variable ""BACKUPDAYS"" with value ""7"""
varname=STRING|"BACKUPDAYS"
varvalue=STRING|"7"
operator=STRING|"1"
value1=STRING|"{FileExists({TaskFolder}\*.tsk)}"
message=STRING|"Wrong task folder. Reconfigure the task, please"
type=STRING|"2"
Name=STRING|"Break"
ActionID=STRING|"A_FOLDER_SYNCHRONIZE"
Name=STRING|"Synchronize Folders"
clearro=STRING|"0"
details=STRING|"0"
detailstovar=STRING|"0"
exact=STRING|"0"
foder1=STRING|"{TaskFolder}"
foder2=STRING|"{TodayFolder}"
hidden=STRING|"0"
howsync=STRING|"1"
includeempty=STRING|"0"
includemask=STRING|"*.*"
subdir=STRING|"0"
system=STRING|"0"
twosecprecision=STRING|"1"
Name=STRING|"//Now remove old backup folders"
comment=STRING|"Now remove old backup folders"
Name=STRING|"File Monitor"
UniqueID=INTEGER|45692128
chg=STRING|"1"
chga=STRING|"1"
chgsl=STRING|"1"
chgsm=STRING|"1"
chgtl=STRING|"1"
chgtm=STRING|"1"
del=STRING|"0"
folder1=STRING|"{TaskFolder}"
foldercount=STRING|"1"
incmask=STRING|"*.*"
interval=STRING|"60"
listmode=STRING|"1"
mon_files=STRING|"1"
mon_folders=STRING|"0"
new=STRING|"1"
pass=STRING|"0"
passmode=STRING|"1"
saveresults=STRING|"0"
subfolders1=STRING|"0"
Yes, mine too. But on the seventh day it starts failing when removing the folder.
Yes!! I reproduced your problem and get the same error message
-: 02.05.2022 20:11:40: Executing "15.Log Message"
-: 02.05.2022 20:11:40: Removing c:\auto\RoboTaskBackup\20220430
-: 02.05.2022 20:11:40: Executing "16.Remove Nonempty Folder ({OldFolder})"
-: 02.05.2022 20:11:40: File access denied
-: 02.05.2022 20:11:40: Failed execute 'ExecAction with exception: File access denied' (C:\Program Files\RoboTask\Plugins\Files\FileMan.rtp)
-: 02.05.2022 20:11:40: An error occurred. Reconfigure this step.
-: 02.05.2022 20:11:40: Task execution is aborted
The problem is in permissions of backup folder.
Check the folder 20220425. It seems the folder is empty BUT you can not delete it. because you have not enough permissions to remove it.
Also check permissions on backup folder and on all nested files and folders
cagigas
Post by cagigas »
I tried your last version's task with the log message that allows to see the problematic folder.
The problematic folder is the number 8, sorted by name in descending order, the one that should be deleted today to end with 7 folders only. All as expected.
I changed permissions to allow "total control" on that folder, also on root folder C:\TaskBackup (I'm now testing the task in this folder).
When I check the permissions that I just changed I can see they are automtically set back to initial state ("read only").
Maybe my windows 10 or my antivirus kaspersky is blocking me to not to change folder permissions. I tried to add "total control" in advanced options with no success.
Try to remove folder c:\taskBackup\20220425 manually in Windows Explorer.
I'm sure that you will get the same error
Also, check the folder contents. I'm sure that the folder is already empty.
cagigas
Post by cagigas »
Yes, the folder is empty, but I can delete the folder manually without error messages; it goes directly to recicle bin.
I suspect of sharing access rights, or Robotask does not have permissions to delete folders, although I have deleted folders before with Robotask and it went fine
Very extrange :(((
...it goes directly to recicle bin.
Moving to Recycled BIN and delete folder (without recycled bin) are not the same operations.
To delete file or folder without recycled bin select the file and use keys Shift+Del
...or Robotask does not have permissions to delete folders...
RoboTask has exactly the same permissions as other applications in your session by default
cagigas
Post by cagigas »
Oleg, the problem is in the "Syncronize folders" step. It locks the folder, hence the access error message.
Please have a look at this simple task:
CatID=INTEGER|1023498607
ExternalName=STRING|"Task60"
ID=INTEGER|936654536
Name=STRING|"BorrarCarpeta"
Name=STRING|"Create Folder (C:\TaskBackup\test)"
newfolder=STRING|"C:\TaskBackup\test"
Name=STRING|"Delay 5 sec"
delay=STRING|"5"
dimension=STRING|"1"
Name=STRING|"Remove Nonempty Folder  (C:\TaskBackup\Test)"
folder=STRING|"C:\TaskBackup\Test"
It works perfectly in my computer. It creates a folder "test" and then it deletes it. No errors, no problems.
I can also delete folders with Robotask that I have created manually before.
The step "syncronize folders" is locking the folders. These folders are locked in a way that even if I copy and rename them I still cannot remove them.
Thanks,
Oscar
cagigas
Post by cagigas »
(edited to remove incorrect code)
I use the task with "Synchronize folders" step several years without problem.
It seems the problem is not here
cagigas
Post by cagigas »
Just for your information, I have changed the "Delete non-empty folder" step to "delete file (with folder)" step and it works fine now. There seems to be a problem with "delete folder" in my computer.
