psbtheone
Posts: 2 Joined: Wed Jun 10, 2020 6:43 am
Post
by psbtheone » Wed Jun 10, 2020 7:07 am
Hi Oleg,
Thanks for your sharing this good task for backup of all tasks to a certain location. But, after exporting tasks, its difficult to identify a task by name in backup location, so i have created one subtask to be called from this backup task.
This subtask will read each task for its name and rename the task to its name before exporting it to a backup location.
Check this subtask:
ExportTaskWithName.tsk
CatID=INTEGER|1723571677
ContinueOnError=INTEGER|1
ExternalName=STRING|"Task39"
ID=INTEGER|368097659
LocalVariables=STRING|"CNT1=,name=,NAME1=,POSITION=,TEXT="
Name=STRING|"ExportTasks"
Name=STRING|"File Loop"
date1=STRING|"20200307"
date2=STRING|"20200307"
destvar=STRING|"TSKFILE"
DuringMinutes=STRING|"1"
file0=STRING|"{TaskFolder}\*.tsk"
searchkind=STRING|"0"
sort=STRING|"1"
sortby=STRING|"1"
sortorder=STRING|"1"
subdirs=STRING|"1"
timesize=STRING|"0"
Name=STRING|"Simple Loop"
begin=STRING|"10"
end=STRING|"20"
variable=STRING|"CNT1"
external=STRING|"1"
filename=STRING|"{TSKFILE}"
linecount=STRING|"0"
linenum=STRING|"{CNT1}"
variable=STRING|"TEXT"
Name=STRING|"STR Extract"
amount=STRING|"13"
from=STRING|"1"
source=STRING|"{TEXT}"
variable=STRING|"position"
case=STRING|"1"
value1=STRING|"{POSITION}"
value2=STRING|"Name=STRING|"""
amount=STRING|"200"
from=STRING|"14"
variable=STRING|"name"
ActionID=STRING|"A_STR_TRIM"
Name=STRING|"STR Trim"
custom=STRING|"1"
customchar=STRING|""""
eol=STRING|"0"
lead=STRING|"1"
source=STRING|"{name}"
spaces=STRING|"0"
tabs=STRING|"0"
trailing=STRING|"1"
variable=STRING|"name1"
ActionID=STRING|"A_FILE_COPY"
Name=STRING|"Copy/Move File"
destdir=STRING|"{TODAYFOLDER}"
f_count=STRING|"1"
file0=STRING|"{TSKFILE}"
hidden=STRING|"1"
ifexists=STRING|"0"
move=STRING|"0"
rename=STRING|"1"
renamemask=STRING|"{name1}.tsk"
subdir=STRING|"0"
system=STRING|"1"
Posts: 3219 Joined: Thu Jan 01, 1970 1:00 am
Post
by Oleg » Wed Jun 10, 2020 10:32 am
Very good.
Also look at the these demo tasks (included into installation package):
[DEMO] Retrieve task names - it creates the file map.txt in the task folder. Each line looks like this
06C2F733 = Retrieve task names
task_file_name = Task_name
[DEMO] Retrieve task parameters to CSV - it creates CSV file map.csv wth three fields:
Task_File_Name
Task_Name
Task_External_Name
You can import this file into Excel and sort the list by any column
cagigas
Posts: 10 Joined: Mon Apr 18, 2022 10:57 am
Post
by cagigas » Tue Apr 19, 2022 3:30 pm
I am using version 9 of Robotask. I tried the task "Backup your tasks" but when deleting the old folders it gives me an error:
"Failed execute 'ExecAction with exception: File access denied' (C:\Program Files\RoboTask\Plugins\Files\FileMan.rtp)"
I don't have any other tasks accessing to that file. Any ideas?
Thanks
Oscar
Post
by Oleg » Thu Apr 21, 2022 10:59 am
May I have a look at
your task?
C:\Program Files\RoboTask\Plugins\Files\FileMan.rtp is not a task, this is binary module of RoboTask.
It seems you want to remove binary modules of RoboTask and break RoboTask
Where do you want to save tasks?
the original example saves tasks in folder c:\TaskBackup
I use the similar task too for backup my tasks. It works without problem
cagigas
Post
by cagigas » Fri Apr 29, 2022 11:26 am
Thanks Oleg for your reply. This is the task:
https://robotask.com/tasks/Demo/[DEMO]% ... ackup).tsk
CatID=INTEGER|10
ExternalName=STRING|"Task26"
ID=INTEGER|913310745
Name=STRING|"[DEMO] Backup your tasks (daily backup) (imported)"
Action14=FOLDER
Action15=FOLDER
Action16=FOLDER
Action17=FOLDER
Name=STRING|"Create local variable ""BACKUPFOLDER"" with value ""c:\auto\RoboTaskBackup"""
varname=STRING|"BACKUPFOLDER"
varvalue=STRING|"c:\auto\RoboTaskBackup"
Name=STRING|"Create local variable ""OLDFOLDER"" with value """""
varname=STRING|"OLDFOLDER"
Name=STRING|"Create local variable ""CNT"" with value ""0"""
varname=STRING|"CNT"
varvalue=STRING|"0"
[Actions\Action12\Params]
date1=STRING|"20130328"
date2=STRING|"20130328"
destvar=STRING|"OLDFOLDER"
file0=STRING|"{BackupFolder}\*.*"
searchkind=STRING|"1"
sort=STRING|"1"
sortby=STRING|"0"
subdirs=STRING|"1"
timesize=STRING|"0"
Name=STRING|"Increment variable ""cnt"""
[Actions\Action13\Params]
incement=STRING|"1"
vaiable=STRING|"cnt"
[Actions\Action14]
[Actions\Action14\Params]
operator=STRING|"3"
type=STRING|"1"
value1=STRING|"{Cnt}"
value2=STRING|"{BackupDays}"
[Actions\Action15]
Name=STRING|"Remove Nonempty Folder ({OldFolder})"
[Actions\Action15\Params]
deletefolder=STRING|"1"
folder=STRING|"{OldFolder}"
[Actions\Action16]
[Actions\Action17]
Name=STRING|"Create local variable ""TODAYFOLDER"" with value ""{BackupFolder}\{Year}{MonthNo}{Day}"""
varname=STRING|"TODAYFOLDER"
varvalue=STRING|"{BackupFolder}\{Year}{MonthNo}{Day}"
Name=STRING|"Create local variable ""BACKUPDAYS"" with value ""7"""
varname=STRING|"BACKUPDAYS"
varvalue=STRING|"7"
operator=STRING|"1"
value1=STRING|"{FileExists({TaskFolder}\*.tsk)}"
message=STRING|"Wrong task folder. Reconfigure the task, please"
type=STRING|"2"
Name=STRING|"Break"
ActionID=STRING|"A_FOLDER_SYNCHRONIZE"
Name=STRING|"Synchronize Folders"
clearro=STRING|"0"
details=STRING|"0"
detailstovar=STRING|"0"
exact=STRING|"0"
foder1=STRING|"{TaskFolder}"
foder2=STRING|"{TodayFolder}"
hidden=STRING|"0"
howsync=STRING|"1"
includeempty=STRING|"0"
includemask=STRING|"*.*"
subdir=STRING|"0"
system=STRING|"0"
twosecprecision=STRING|"1"
Name=STRING|"//Now remove old backup folders"
comment=STRING|"Now remove old backup folders"
Name=STRING|"File Monitor"
UniqueID=INTEGER|1287816954
chg=STRING|"1"
chga=STRING|"1"
chgsl=STRING|"1"
chgsm=STRING|"1"
chgtl=STRING|"1"
chgtm=STRING|"1"
del=STRING|"0"
folder1=STRING|"{TaskFolder}"
foldercount=STRING|"1"
incmask=STRING|"*.*"
interval=STRING|"60"
listmode=STRING|"1"
mon_files=STRING|"1"
mon_folders=STRING|"0"
new=STRING|"1"
pass=STRING|"0"
passmode=STRING|"1"
saveresults=STRING|"0"
subfolders1=STRING|"0"
The only change I did was to change the BACKUPFOLDER variable to c:\auto\RoboTaskBackup (from c:\TaskBackup)
From your reply I understand that maybe my installation is corrupted.
Post
by Oleg » Mon May 02, 2022 10:00 am
I've just tested your task. It works correctly.
save all tasks to folder
C:\auto\RoboTaskBackup\20220502\ and don't try to remove RoboTask files
cagigas
Post
by cagigas » Mon May 02, 2022 4:36 pm
Yes, mine too. But on the seventh day it starts failing when removing the folder.
Should I backup my tasks and reinstall the software?
What about admin rights or something?
Thanks
Post
by Oleg » Mon May 02, 2022 5:32 pm
Maybe you use some non-standard permissions for backup folder.
I use this task for incremental backup long time without problem
Post
by Oleg » Mon May 02, 2022 5:36 pm
Can you remove old folder manually?
Post
by Oleg » Mon May 02, 2022 5:40 pm
I've just tested the task with many backup folders. It works!
