Automatically delete files after a designated time?
mploug
Post by mploug »
Is it possible to add an action that automatically deletes files in a self-selected
folder after a designated time - let us say 24 ours?
What is the procedure in which case?
Thanks in advance.
Re: Automatically delete files after a designated time?
Look at these examples:
[DEMO] Clear Temporary Folder.tsk
[DEMO] View Temp Files.tsk
These tasks remove temporary files older than 7 days. You can set another timeout.
Attack to the task Scheduler or Cyclic trigger (suppose every 2 hours)
These tasks are included into installation package too. You can see them when you install RoboTask
mploug
Post by mploug »
Hi Oleg,
Thank you.
I will look at it.
Kind regards,
Martin.
