pack files structure
rgonzalez
Post by rgonzalez »
Hello again!
I'm using pack files action to compress a folder but I have 2 issues:
1- If there's an empty subfolder, it doesn't get added to the zipped structure. Only subfolders with files inside are added. This brakes the structure of the compressed folder.
2- Whenever I compress a folder, the full path to the folder is added to the structure, for example compressing "C:\Users\Rafa\Desktop\Folder\*.*" adds the folder "Users\Rafa\Desktop\Folder" to the structure of the compressed file and then the files that I choose, inside the folder. How can I stop this to exclude the full path off the structure? I tried "junk folder names" option but that removes all folders.
Thank you!
Re: pack files structure
...If there's an empty subfolder, it doesn't get added to the zipped structure...
Pack files in version 6.8 contains new parameter: Include empty folders
Turn this option ON. See screenshot below:
There is small trick.
Suppose we need to pack the folder c:\User Data\john\pictures with subfolders but we don't need full path from root.
1. Change current folder to the folder c:\userDate\john\pictures (see action Change Folder)
2. Next, pack files by mask *.*. You do not need to specify folder, just pack all files in the current folder.
rgonzalez
Post by rgonzalez »
Thank you, I'll give it a try! :o
