hongkwok
Posts: 4 Joined: Mon Nov 23, 2015 8:31 am
Post
by hongkwok » Tue Sep 06, 2016 12:31 pm
I cannot run "Run Command-line utility"
Please help
the test.bat is simple:
Here is the log
I: 9/6/2016 7:27:30 PM: ****** Starting task: Test ******************
I: 9/6/2016 7:27:30 PM: Executing "1.Run command-line utility: test.bat "
E: 9/6/2016 7:27:30 PM:
E: 9/6/2016 7:27:30 PM: An error occurred. Step #1 (Run command-line utility: test.bat ).
I: 9/6/2016 7:27:30 PM: Task executed successfully
CatID=INTEGER|1476211084
ContinueOnError=INTEGER|1
ExternalName=STRING|"Task34"
ID=INTEGER|938281814
Name=STRING|"Test"
OnErrorTaskID=INTEGER|200524284
ActionID=STRING|"A_MISC_RUNCONSOLEAPP"
Name=STRING|"Run command-line utility: test.bat "
convertansi=STRING|"0"
ifnonzero=STRING|"0"
program=STRING|"C:\Batch\test.bat"
saveexitcode=STRING|"0"
saveoutput=STRING|"0"
workdir=STRING|"C:\Batch"
Posts: 3310 Joined: Thu Jan 01, 1970 1:00 am
Post
by Oleg » Tue Sep 06, 2016 12:54 pm
What operating system do you use?
Windows 10 do this without problems.
Try to run batch file via command interpreter
(cmd.exe)
CatID=INTEGER|1639840329
ExternalName=STRING|"Task42"
ID=INTEGER|291196667
Name=STRING|"Run command-line utility: test.bat ..."
Name=STRING|"Run command-line utility: cmd.exe /c ""D:\Temp\test.bat"""
outputvar=STRING|"out"
params=STRING|"/c ""D:\Temp\test.bat"""
program=STRING|"cmd.exe"
saveoutput=STRING|"1"
Name=STRING|"Show ""{out}"""
msg0=STRING|"{out}"
hongkwok
Post
by hongkwok » Tue Sep 06, 2016 4:29 pm
It works
I'm using server 2012 R2
Why do I have to add cmd.exe there?
Post
by Oleg » Tue Sep 06, 2016 4:46 pm
Generally this action is for command-line utilities (that is EXE files)
BAT or CMD file is not an standalone executable file. It is only a text script.
System runs the CMD.EXE to perform this script in any case.
BTW I just tested the task without CMD.EXE (run test.bat directly) on our test Windows Server 2012 Standard
It works!
hongkwok
Post
by hongkwok » Wed Sep 07, 2016 2:04 am
It worked fine in my 2012 R2 last week.
But I don't know why it fail this week.
It requires cmd.exe this week
Can you guess why?
thanks
Post
by Oleg » Wed Sep 07, 2016 10:02 am
Probably some system settings (or 3-rd party software like as antivirus)
Unfortunately I can't say something more particular.
