Search for Files - Create File List save empty variable
gabageno
Post by gabageno »
Hi, I'm trying to read the list of files in a folder and then do actions for each filename.
I use the "Search for files" action. I give them the path and wildcard to filter files. Set "Save the File list to Variable" option and add another action to show the variable content in a dialog. But when I run the task the dialog box is empty.
I've used others ways to try to know the content of the variable but always is empty.
If I use the option "Save the List to File" then the file is created with the correct content of the folder.
Why I can´t get this in a variable???
please help
Re: Search for Files - Create File List save empty variable
maybe you are doing some wrong.
Look at my example below (only two steps). It works
CatID=INTEGER|263000617
ExternalName=STRING|"Task9"
ID=INTEGER|859223760
Name=STRING|"get file list"
Name=STRING|"Create File List (variable: myvar)"
After=STRING|"0"
aftercount=STRING|"0"
AfterLine=STRING|"0"
Before=STRING|"0"
beforecount=STRING|"0"
BeforeLine=STRING|"0"
date1=STRING|"20160705"
date2=STRING|"20160705"
destvar=STRING|"myvar"
DuringMinutes=STRING|"1"
file0=STRING|"c:\temp\*.txt"
savetofile=STRING|"0"
savetovar=STRING|"1"
searchkind=STRING|"0"
sort=STRING|"0"
sortby=STRING|"0"
sortorder=STRING|"0"
subdirs=STRING|"1"
Name=STRING|"Show ""{myvar}"""
msg0=STRING|"{myvar}"
