Get part of web page
deesloop
Post by deesloop »
I want to log into a web site, navigate to a new page and pull a data table from it and then display the table.
I've got the web login working fine and the navigation to the second page
Howver I cant see how to save the data from the site.
Any ideas how this can be achieved?
Thanks
Re: Get part of web page
Simplest way (if you are using external web browser): Ctrl-A, Ctrl-C
That is: "select all" and "copy to clipboard"
Next, you can get the text from clipboard and parse it.
deesloop
Post by deesloop »
I'm using your the browser.
deesloop
Post by deesloop »
Sorted it.
It's not CTRL - C for copy, you have to use the key combo
In this case use Web Page information action
Leave "Web address" field empty.
You can save HTML code or Text of the page into variable. The action saves complete code or text.
You have to parse this text and extract necessary part yourself
deesloop
Post by deesloop »
I have PMD you the task
The issue I have is that this runs OK when robotask is running but I dont want robotask running all the time.
This is to be an as and when type task, launched with a shortcut
If I run the task without robotask running and i I get a dialogue box
"Please wait until all the running tasks will be finished"
Is this because of the dialogue box that is open?
I've edited the task to open Notepad and paste that way.
But the dialogue box is much neater looking.
Is there a way to NOT display the please wait untill all running task will be finished?
Also, I dont seem to be able to run the web browser at an x,y size below 20 or so?
I dont want them to see the bowser at all - or at least make it tiny...
I think that this is not good idea. You can get many inconveniences.
You see this warning message when RoboTask get shutdown command but some tasks is being executed as yet.
Could I instead run notepas and paste the contents in there?
If you put some text into system clipboard you can paste it to any input field.
Web documents actions have the option "Hide browser's window"
