clipboard problem
redbreather
clipboard problem
Post by redbreather »
Hi!
When i want to get clipboard content, nothing happens. When i check the clipboard, the data is there. I'm running a Swedish version of Windows, is that the problem?
clipboard problem
RoboTask can get text clipboard content only. If clipboard data is not a text or it can't be transformed to text, you may have some problems.
Get Text action assign the clipboard content to any user variable. Next you can use this variable in other actions or tasks. Any visible effects should not occur.
