combine 2 csv files
rice1973
combine 2 csv files
Post by rice1973 »
Hi Oleg,
I have to csv files.
Example;
file1.csv;
"12323","nice","good",
"31245","not nice,""not good",
file2.csv;
"weather","water","fire"
"nice weahter","dry","wet"
output must be like;
"12323","nice","good","weather","water","fire"
"31245","not nice,""not good","nice weahter","dry","wet"
Robotask rules! :)
userXXX
Re: combine 2 csv files
Post by userXXX »
Maybe this works for you:
CatID=INTEGER|347244376
ExternalName=STRING|"Task37"
ID=INTEGER|1278379756
LocalVariables=STRING|"L_FILE1=,L_FILE2=,L_OUT=,L_ROW_FILE1=,L_ROW_FILE2=,L_ROWCNT=,L_ROWNUM=1,L_TMP_DIR=C:\temp"
Name=STRING|"combine 2 csv files"
Name=STRING|"Set variable ""L_FILE1"" with value ""{L_TMP_DIR}\file1.csv"""
varname=STRING|"L_FILE1"
varvalue=STRING|"{L_TMP_DIR}\file1.csv"
Name=STRING|"Set variable ""L_FILE2"" with value ""{L_TMP_DIR}\file2.csv"""
varname=STRING|"L_FILE2"
varvalue=STRING|"{L_TMP_DIR}\file2.csv"
ActionID=STRING|"A_TXT_NUMBEROFLINES"
Name=STRING|"TXT Number of Lines"
external=STRING|"1"
filename=STRING|"{L_FILE1}"
linecount=STRING|"0"
variable=STRING|"L_ROWCNT"
Name=STRING|"Simple Loop"
begin=STRING|"1"
end=STRING|"{L_ROWCNT}"
variable=STRING|"L_ROWNUM"
external=STRING|"1"
linenum=STRING|"{L_ROWNUM}"
variable=STRING|"L_ROW_FILE1"
external=STRING|"1"
filename=STRING|"{L_FILE2}"
variable=STRING|"L_ROW_FILE2"
Name=STRING|"Set variable ""L_OUT"" with value ""{L_OUT}{L_ROW_FILE1}{L_ROW_FILE2}{EOL}"""
varname=STRING|"L_OUT"
varvalue=STRING|"{L_OUT}{L_ROW_FILE1}{L_ROW_FILE2}{EOL}"
Name=STRING|"Create text file {L_TMP_DIR}\combination.csv"
encode=STRING|"0"
fileexists=STRING|"0"
filname=STRING|"{L_TMP_DIR}\combination.csv"
line0=STRING|"{L_OUT}"
suppress=STRING|"1"
You forgot the comma in the step #7
you have to use expression:
{L_OUT}{L_ROW_FILE1},{L_ROW_FILE2}{EOL}
userXXX
Post by userXXX »
Oleg wrote:You forgot the comma in the step #7
Yes, because it's already included in file1.csv of his example. ;)
Exactly :D
