How to extract characters from a file name?
ntesla
Post by ntesla »
Hi
I'm new to Robotask but I'm loving it. Great program! I've been telling everyone I know about it!
There's just one things I can't figure out. If Robotask identifies a file (eg, 'qwk*.txt') is there a way to extract the characters that the wildcard represents and assign them to a variable?
If you can provide any insights I would be very grateful.
Thank you in advance
Re: How to extract characters from a file name?
Do you want collect all filenames by mask?
You can use File Loop.
See example below:
CatID=INTEGER|317955339
ExternalName=STRING|"Task881"
ID=INTEGER|1152080012
Name=STRING|"Collect files 1"
Name=STRING|"Create local variable ""MASK"" with value ""qwk*.txt"""
varname=STRING|"MASK"
varvalue=STRING|"qwk*.txt"
Name=STRING|"Create local variable ""FILENAME"" with value """""
varname=STRING|"FILENAME"
Name=STRING|"File Loop"
date1=STRING|"20140514"
date2=STRING|"20140514"
destvar=STRING|"FILENAME"
DuringMinutes=STRING|"1"
file0=STRING|"d:\incoming\{mask}"
searchkind=STRING|"0"
sort=STRING|"0"
sortby=STRING|"0"
sortorder=STRING|"0"
subdirs=STRING|"0"
timesize=STRING|"0"
WithoutPath=STRING|"1"
Name=STRING|"Show ""{filename}"""
msg0=STRING|"{filename}"
Also see Search for Files action
See another example below:
ExternalName=STRING|"Task884"
ID=INTEGER|985721994
Name=STRING|"Collect files 2"
Name=STRING|"Create local variable ""FILENAMES"" with value """""
varname=STRING|"FILENAMES"
Name=STRING|"Create File List (variable: FileNames)"
After=STRING|"0"
aftercount=STRING|"0"
AfterLine=STRING|"0"
Before=STRING|"0"
beforecount=STRING|"0"
BeforeLine=STRING|"0"
destvar=STRING|"FileNames"
savetofile=STRING|"0"
savetovar=STRING|"1"
sort=STRING|"0"
sortby=STRING|"0"
subdirs=STRING|"0"
Name=STRING|"Show ""{FileNames}"""
msg0=STRING|"{FileNames}"
Next you can process the list in Text loop
ntesla
Post by ntesla »
Many thanks. I'll look into it.
