Converting CSV to XLSX
laurann
Post by laurann »
Hello everyone,
I want to make a Robotask to convert a CSV file to a XLSX file. Is this possible within Robotask?
And if that is possible could you give me a little intro in it.
Many thanks,
Re: Converting CSV to XLSX
RoboTask can't work directly with XLS (or XLSX) files.
But you can use MS EXCELL for this. You can create a task which opens the CSV file and save it as XLS file.
