Selection in Windows Explorer
ralphberner
Post by ralphberner »
Is there a possibility to analyze automatically what is selected in the frontmost windows explorer-window and let RoboTask decide what to do accordig to that?
I want to do one task if exactly one File is selected and do a different task if more than one file is selected or even do a third task if subfolders are selected.... ;)
I work with a similar tool for years which is lacking of exactly this function. Im looking for a alternative. :geek:
Re: Selection in Windows Explorer
See the task below. This example shows how to analyze how many files are selected and whether sub-folders are selected
You can copy files into clipboard and get the list as text: one file fer line
CatID=INTEGER|1199514847
ExternalName=STRING|"Task112"
ID=INTEGER|1148249851
Name=STRING|"Check files"
Action14=FOLDER
Action15=FOLDER
Action16=FOLDER
Action17=FOLDER
Action18=FOLDER
Action19=FOLDER
Action20=FOLDER
Action21=FOLDER
Name=STRING|"Copy"
mode=STRING|"1"
Name=STRING|"Text Loop"
destvar=STRING|"STR"
line0=STRING|"{List}"
sourcetext=STRING|"1"
Enabled=INTEGER|0
Name=STRING|"Show ""{str}"""
msg0=STRING|"{str}"
msg1=STRING|"folder {FolderExists({str})}"
msgcount=STRING|"2"
[Actions\Action12\Params]
value1=STRING|"{FolderExists({str})}"
Name=STRING|"Set variable ""FOLDERSELECTED"" with value ""true"""
[Actions\Action13\Params]
varname=STRING|"FOLDERSELECTED"
varvalue=STRING|"true"
[Actions\Action14]
Name=STRING|"Break"
[Actions\Action15]
[Actions\Action16]
[Actions\Action17]
[Actions\Action17\Params]
value1=STRING|"{folderselected}"
[Actions\Action18]
Name=STRING|"Show ""Selected {cnt} items"""
[Actions\Action18\Params]
icon=STRING|"0"
msg0=STRING|"Selected {cnt} items"
msg2=STRING|"Folders are selected!!!"
msgcount=STRING|"3"
[Actions\Action19]
ActionID=STRING|"A_FLOW_ELSE"
Name=STRING|"Else"
Name=STRING|"Create local variable ""LIST"" with value """""
varname=STRING|"LIST"
[Actions\Action20]
[Actions\Action20\Params]
msg1=STRING|"Folders are not selected"
msgcount=STRING|"2"
[Actions\Action21]
Name=STRING|"Create local variable ""STP"" with value """""
varname=STRING|"STP"
Name=STRING|"Create local variable ""CNT"" with value """""
varname=STRING|"CNT"
Name=STRING|"Create local variable ""FOLDERSELECTED"" with value ""false"""
varvalue=STRING|"false"
Name=STRING|"Get Text"
variable=STRING|"list"
Enabled=INTEGER|0
Name=STRING|"Show ""{list}"""
msg0=STRING|"{list}"
ActionID=STRING|"A_STR_TRIM"
Name=STRING|"STR Trim"
custom=STRING|"0"
eol=STRING|"1"
lead=STRING|"1"
source=STRING|"{list}"
spaces=STRING|"1"
tabs=STRING|"1"
trailing=STRING|"1"
ActionID=STRING|"A_TXT_NUMBEROFLINES"
Name=STRING|"TXT Number of Lines"
external=STRING|"0"
line00000000=STRING|"{list}"
variable=STRING|"cnt"
UnigueID=INTEGER|16445185
hotkey=STRING|"24646"
Save the task into a file and use Task->Import in order to import into RoboTask.
Do not forget to enable this task after importing, because imported tasks are disabled by default.
Now you can select some files in windows explorer and press Ctrl-Shift-F and task will calculate amount of selected files and check folders within the list.
