Set Focus on Dialog Box
krhoades
Post by krhoades »
Good Morning!
I have photographs that are downloaded to a folder after the camera is plugged in via the USB port. I have a task that monitors this folder and once it detects the photographs it kicks off a script written in basic that allows you to make choices. It there anyway to set focus to the dialog box that pops up. You just cannot start typing or even hit the tab key. You have to take the mouse and click in the dialog box that pops up. It would be easier to just start typing the order number instead of having to grab the mouse, set focus and then type your order number.
Thanks!
krhoades
Re: Set Focus on Dialog Box
Post by krhoades »
I think I found a work around by adding a window watcher and then using "move to object"
Yes, second task with Window watcher is the best way. I wanted to write about this, but you have found the solution more quickly.
See below the task with Window Watcher. Maybe it will be helpful for somebody else:
CatID=INTEGER|317955339
ExternalName=STRING|"Task839"
ID=INTEGER|1843655335
Name=STRING|"Focus window ""Sax ActiveX Scripting""..."
Name=STRING|"Focus window ""Sax ActiveX Scripting"""
action=STRING|"0"
caption=STRING|"0"
child=STRING|"0"
class=STRING|"1"
classexact=STRING|"0"
exact=STRING|"0"
findmode=STRING|"0"
hidden=STRING|"0"
processall=STRING|"0"
wincaption=STRING|"Sax ActiveX Scripting"
winclass=STRING|"WinWrapBasicDynDlgWindow.6"
EventID=STRING|"E_WINDOW_WATCHER"
UnigueID=INTEGER|16445953
assignvariable=STRING|"0"
child=STRING|"0"
exact=STRING|"0"
hidden=STRING|"0"
usecaption=STRING|"0"
useclass=STRING|"1"
useparameter=STRING|"0"
watchfor=STRING|"1"
This task should catch any BASIC dialog by ClassName.
