Random Delay for Cyclic Trigger
DEE
Post by DEE »
Is there a way to set my task to run between a random range of 500 and 1000 seconds? I saw the system variable {RandomValue(1000)} but I need to set a higher starting range than 1.
Vara04
Re: Random Delay for Cyclic Trigger
Post by Vara04 »
May be you can try : {RandomValue(500)} + 500
Chris
(Robotask v6.4.2 on Win2008 x64)
Unfortunately Cyclic trigger can't set various period.
It uses fixed value of period when it starts and doesn't change the period while trigger is working
