Can Windows API or DLL functions be run ?
User avatar
robotask
Post by robotask »
Does robotask support DLL calls or using Windows API ?
User avatar
robotask
Re: Can Windows API or DLL functions be run ?
Post by robotask »
for illustration purpose only, here is a DLL call from Automate 9 using windows API function(s) from user32.dll
<AMVARIABLE NAME="a"></AMVARIABLE>
<AMEXECUTEDLLFUNCTION DLLFILEPATH="C:\Windows\SysWOW64\user32.dll" METHODNAME="MessageBox" RETURNTYPE="Void"><ARGUMENT ARGTYPE="Int32" ARGVALUE="0" /><ARGUMENT ARGTYPE="String" ARGVALUE="Hi" /><ARGUMENT ARGTYPE="String" ARGVALUE="Bye" /><ARGUMENT ARGTYPE="Int32" ARGVALUE="0" /></AMEXECUTEDLLFUNCTION>
You can use Basic script. See example below:
Private Declare Function ShellExecute Lib "shell32.dll" Alias "ShellExecuteA" _
  (ByVal hWnd As Long, ByVal lpOperation As String, _
  ByVal lpFile As String, ByVal lpParameters As String, _
  ByVal lpDirectory As String, ByVal nShowCmd As Long) As Long
Private Declare  Function MyMsgBox Lib "User32.dll" Alias "MessageBox" _
   (ByVal hWnd As Integer, ByVal txt As String, ByVal caption As String, _
   ByVal typ As Integer ) As Integer
Sub Main
ShellExecute(0, "open", "notepad.exe", "", ".", 10)
MyMsgBox(0,"Notepad has been started", "Notification", 0)
End Sub
You can get basic Plugin for RoboTask here:
http://www.robotask.com/downloads/
Direct link:
http://www.robotask.com/downloads/BasicForRoboTask.exe
