Copy&Paste functions in *.txt
Viker
Post by Viker »
I want to create some script, but I haven't such result I needed.
I have many TXT files for reading.
One file with constant text – CONSTANT.TXT.
And one file for writing – WRITE.TXT.
I need :
1)Open one of TXT files for reading
2)Copy first string of text and paste it to WRITE.TXT
3)Open CONSTANT.TXT copy first string of text and pust it to WRITE.TXT after text from point 1. Going to second string
4)Open TXT file from point 1, and copy second string
5)Open CONSTANT.TXT copy second string of text and pust it to WRITE.TXT after text from point 1. Going to third string
bla bla bla...
And main problem, that this script must started when I click on "NEW Message" button in Outlook, and result text from WRITE.TXT must append as signature to message.
PLZ HELP ME ;)
I think, that your files contains not many lines.
Read the Const.txt file into the user variable named const (see task below) like comma separated text. Next you can access to each line as const(i) where i is line number.
You can form the write.txt file and next force Outlook Express to begin a new message.
For example see task below. In order to import this task into RoboTask save text of task to any *.tsk file and use "Task | Import " menu command.
;* RoboTask Task file *
;* Do not edit!       *
CatID=INTEGER|565106205
ExternalName=STRING|"Task185"
ID=INTEGER|1792563564
Name=STRING|"Combine two texts demo"
Action14=FOLDER
Action15=FOLDER
Action16=FOLDER
Action17=FOLDER
Name=STRING|"Delete File"
Count=STRING|"1"
deletedirs=STRING|"0"
file0=STRING|"c:\write.txt"
subdir=STRING|"0"
ToRecycleBin=STRING|"0"
Name=STRING|"Set variable ""LINE_NO"" with value ""0"""
varname=STRING|"LINE_NO"
varvalue=STRING|"0"
Name=STRING|"Text Loop"
destvar=STRING|"LINE"
file=STRING|"c:\text.txt"
linecount=STRING|"0"
sourcetext=STRING|"0"
Name=STRING|"Create text file c:\write.txt"
[Actions\Action12\Params]
fileexists=STRING|"1"
filname=STRING|"c:\write.txt"
line0=STRING|"{line}"
line1=STRING|"{Const({Line_No})}"
linecount=STRING|"2"
[Actions\Action14]
Name=STRING|"Send keys to ""- Outlook Express"""
[Actions\Action14\Params]
currentwindow=STRING|"0"
fixedwindow=STRING|"0"
keylayout=STRING|"0"
keys=STRING|"""%(F){ENTER}{ENTER}{DELAY 300}{TAB}{TAB}{TAB}"""
sendkind=STRING|"0"
wincaption=STRING|"- Outlook Express"
[Actions\Action15]
[Actions\Action15\Params]
currentwindow=STRING|"1"
keys=STRING|"""%(I){DOWN}{ENTER}{DELAY 100}c:\write.txt{enter}"""
sendkind=STRING|"0"
[Actions\Action16]
Name=STRING|"Remove variable ""LINE"""
[Actions\Action16\Params]
varname=STRING|"LINE"
[Actions\Action17]
Name=STRING|"Remove variable ""CONST"""
[Actions\Action17\Params]
varname=STRING|"CONST"
Name=STRING|"Set variable ""CONST"" with value """""
file=STRING|"c:\const.txt"
operator=STRING|"7"
value1=STRING|"{const}"
Name=STRING|"Set variable ""CONST"" with value """"{line}"""""
varvalue=STRING|"""{line}"""
ActionID=STRING|"A_FLOW_ELSE"
Name=STRING|"Else"
Name=STRING|"Set variable ""CONST"" with value ""{const},""{line}"""""
varvalue=STRING|"{const},""{line}"""
;end of task
Viker
Post by Viker »
SNX, now I have something
like this
[string1 from dynamic file1][string1 from CONST fileC]
[string2 from dynamic file1][string2 from CONST fileC]
[string3 from dynamic file1][string3 from CONST fileC]
[string4 from dynamic file1][string4 from CONST fileC]
and this is cool ;)
But now I must change dynamic file manually.
I have folder with "dynamic" files(1.txt, 2.txt,...), and I make listing of this files to LISTING.TXT(without file path).
On next step I reading this file, and select one file for copying it (from e:\dynamic\*.txt I must copy one file to e:\) - like you say "Read the Const.txt file into the user variable named const (see task below) like comma separated text. Next you can access to each line as const(i) where i is line number. ".
But all files selected, so I can't copy one file. All
e:\dynamic\*.* copied to e:\.
But I needed only e:\DynamicFile.TXT
PS text.txt (from your example) = e:\DynamicFile.TXT
Thanks
