Search and Delete Files on an FTP Site
cclowes
Post by cclowes »
We have root access to an FTP site and, using Filezilla, we can search the site and delete files meeting a date criteria.
We would like to automate this process in Robotask; but I haven't been able to find the commands that would allow me to do so. I've searched this forum and still haven't found anything that applies to what we want to do.
Specifically we would like to search for files that are two weeks older than today's date and delete them. We would like to do this once a day.
I have an idea on how we would create the variables for the search {Year}{Month}{IncDays(-14)}, but I don't know what command to apply them to. I've tried using the Search For Files command, but it doesn't seem to work with FTP.
Any help would be appreciated.
Re: Search and Delete Files on an FTP Site
You should use FTP File loop (or SSL FTP File loop)
Look at the example below. I've just tested this on our server.
SSL FTP actions support plain FTP too
CatID=INTEGER|264082567
ExternalName=STRING|"Task105"
ID=INTEGER|2083680061
Name=STRING|"Find FTP File older 14 days"
ActionID=STRING|"A_SSLFTP_LOGON"
Name=STRING|"SSL FTP Log On"
anonymous=STRING|"1"
host=STRING|"ftp.site.com"
passive=STRING|"1"
port=STRING|"21"
proxypassword=STRING|"2488925200257142494526994"
proxytype=STRING|"3"
tlsmode=STRING|"0"
useproxy=STRING|"0"
username=STRING|"anonymous"
usessl2=STRING|"0"
usessl3=STRING|"0"
usestls=STRING|"1"
Name=STRING|"Create local variable ""C_FILE"" with value """""
varname=STRING|"C_FILE"
Name=STRING|"Create local variable ""C_DATE"" with value """""
varname=STRING|"C_DATE"
ActionID=STRING|"A_SSLFTP_FILELOOP"
Name=STRING|"SSL FTP File Loop"
filenameonly=STRING|"0"
folder=STRING|"/files/*.*"
kind=STRING|"0"
sizesave=STRING|"0"
subfolders=STRING|"0"
timesave=STRING|"1"
vartime=STRING|"C_DATE"
message=STRING|"{C_file}; {c_date}"
operator=STRING|"5"
type=STRING|"2"
value1=STRING|"{c_date}"
value2=STRING|"{DateIncDays(-14)}"
Name=STRING|"Desktop Alert"
defh=STRING|"1"
defw=STRING|"1"
duration=STRING|"5"
height=STRING|"76"
kind=STRING|"0"
message=STRING|"file {c_file} ({c_date}) older than 14 days"
position=STRING|"3"
title=STRING|"Old file"
width=STRING|"330"
You can get File name, file size and file time in the loop.
Next, you can compare these values and check your criteria.
Use variable {DateIncDays(-14)} to calculate necessary date.
...the variables for the search {Year}{Month}{IncDays(-14)}, but I don't know...
If you want to compose date expression manually you should use something like this:
{YearIncDays(-14)}{MonthIncDays(-14)}{IncDays(-14)}
cclowes
Post by cclowes »
Oleg,
Thanks for your reply and the code. I did have a couple of questions...
Creating the local variable for the file name, what do I need to put in as that variable so that I can use the existing file name?
Also, in the If/Then statement you have a desktop alert. Is that where I put the delete statement? And do I put the c_file variable in as the remote file to be deleted?
Variables C_File and C_Date in the example are being assigned in each iteration of the loop (SSL FTP file loop, step #4).
But pay attention that C_file contains the file name only.
You do the loop by /files/*.* . Therefore you should remove /files/{cfile}
Another way:
You can put the action SSL FTP change folder (to /Files folder) before the loop.
Do the loop by *.*
And use {c_file} as parameter of SSL FTP Delete file action.
see new example below. I recommend you to test it on local or test server, because files removing is potentially dangerous operation
CatID=INTEGER|2099193306
ExternalName=STRING|"Task321"
ID=INTEGER|732090254
host=STRING|"localhost"
passive=STRING|"1"
port=STRING|"21"
proxypassword=STRING|"2488925451249452673325197"
tlsmode=STRING|"0"
useproxy=STRING|"0"
usessl2=STRING|"0"
usessl3=STRING|"0"
usestls=STRING|"1"
ActionID=STRING|"A_SSLFTP_CHANGEFOLDER"
Name=STRING|"SSL FTP Change Folder"
folder=STRING|"/files"
folder=STRING|"*.*"
kind=STRING|"0"
sizesave=STRING|"0"
timesave=STRING|"1"
operator=STRING|"5"
type=STRING|"2"
defh=STRING|"1"
defw=STRING|"1"
duration=STRING|"5"
height=STRING|"76"
kind=STRING|"0"
message=STRING|"Delete file {c_file}"
position=STRING|"3"
width=STRING|"330"
ActionID=STRING|"A_SSLFTP_DELETEFILE"
Name=STRING|"SSL FTP Delete File"
file=STRING|"{c_file}"
