calculate with values
jeroen123
Post by jeroen123 »
Dear Oleg,
I read 2 variables from SQL:
varA = 2
varB= 3
I want to set VarC = 2+3 = 5
{VALUE(8)}+{VALUE(9)}-{VALUE(10)} >> this doesnot work...
It must be simple, I just not seem to find this anywhere...
How to do this?
Re: calculate with values
You should use Basic for any arbitrary calculations.
Download and install Basic plugin: http://www.robotask.com/downloads/BasicForRoboTask.exe
Now you can perform necessary calculations. See the example:
CatID=INTEGER|2099193306
ExternalName=STRING|"Task308"
ID=INTEGER|298810074
Name=STRING|"Simple calculations"
Name=STRING|"Create local variable ""VAR1"" with value ""2"""
varname=STRING|"VAR1"
varvalue=STRING|"2"
Name=STRING|"Create local variable ""VAR2"" with value ""3"""
varname=STRING|"VAR2"
varvalue=STRING|"3"
Name=STRING|"Create local variable ""VAR3"" with value ""10"""
varname=STRING|"VAR3"
varvalue=STRING|"10"
Name=STRING|"Create local variable ""RES"" with value """""
varname=STRING|"RES"
Name=STRING|"Evaluate"
expression=STRING|"{var1}-{var2}+{var3}"
variable=STRING|"RES"
Name=STRING|"Show ""Result = {res}"""
msg0=STRING|"Result = {res}"
You can use Basic script action for complex algorithms.
Save the text into a file and use menu Task->Import to import into Robotask.
jeroen123
Post by jeroen123 »
Thanks Oleg!
works fine and simple :D
