can I use this app to create my own server monitoring tool
dlewis61
Post by dlewis61 »
I have several websites. I'd like to create my own server monitoring tool. I have a copy of Robotask. Can I do that? So the output is sent to me via email or text?
Re: can I use this app to create my own server monitoring to
See the example below.
This task retrieves the text of webpage and assign it to variable.
Next, you can see it, put it into email, save to file, analyse it, and so on.
If you want to start the task automatically you can attach some trigger to the task (for example Cyclic event)
If you use the address of inaccessible site you will get the text with error message.
Of course you can monitor the list of sites in the loop. (see Text loop for this purpose)
CatID=INTEGER|2099193306
ExternalName=STRING|"Task101"
ID=INTEGER|1820536911
Name=STRING|"Site monitor example"
Name=STRING|"Create local variable ""PAGETEXT"" with value """""
varname=STRING|"PAGETEXT"
ActionID=STRING|"A_WD_PAGEINFO"
Name=STRING|"Web Page Information"
address=STRING|"http://www.robotask.com/"
autodownload=STRING|"0"
autologon=STRING|"0"
gethtml=STRING|"0"
getlinks=STRING|"0"
gettext=STRING|"1"
htmlbodyonly=STRING|"0"
htmlvar=STRING|"aaa"
keep=STRING|"1"
overwrite=STRING|"0"
textbodyonly=STRING|"0"
textvar=STRING|"pagetext"
Name=STRING|"Run ""notepad.exe """
ifnonzero=STRING|"0"
program=STRING|"notepad.exe"
runas=STRING|"0"
wait=STRING|"0"
Name=STRING|"Delay 1000 ms"
delay=STRING|"10"
Name=STRING|"Put Text"
line0=STRING|"{pageText}"
sourcetext=STRING|"1"
Name=STRING|"Send keys to ""Notepad"""
currentwindow=STRING|"0"
fixedwindow=STRING|"0"
keylayout=STRING|"0"
keys=STRING|"""You can put this text into email body:"",*****************************,^(V),*****************************,"
pause=STRING|"20"
release=STRING|"0"
sendkind=STRING|"0"
wincaption=STRING|"Notepad"
Save the text of the task to a file and use menu Task=>Import in order to import into RoboTask.
