Array of integer
Alex007
Array of integer
Post by Alex007 »
Hi
Can somebody help me please
I am trying to create an array of integers and then use the increment function for each one of the array cells with loop, each time i am getting an error "not valid integer value" or "Illegal name of variable"
Thank you
Alex
Re: Array of integer
Send your example please.
It seems you made a mistake, but I can say nothing without your task
Generally an array is a comma-separated string, like this:
1,2,3,4,5,22,35,0,100
You can make indexed variables: MyVar1, Myvar2, etc.
See the example below:
CatID=INTEGER|2099193306
ExternalName=STRING|"Task53"
ID=INTEGER|1375023030
Name=STRING|"Usage of Indexed Variables"
Name=STRING|"Create local variable ""CNT"" with value """""
varname=STRING|"CNT"
Name=STRING|"Simple Loop"
begin=STRING|"1"
end=STRING|"5"
variable=STRING|"CNT"
Name=STRING|"Create local variable ""MYVAR{CNT}"" with value ""{cnt}"""
varname=STRING|"MYVAR{CNT}"
varvalue=STRING|"{cnt}"
Enabled=INTEGER|0
Name=STRING|"Show ""{MyVar1}"""
msg0=STRING|"{MyVar1}"
msg1=STRING|"{MyVar2}"
msg2=STRING|"{MyVar3}"
msg3=STRING|"{MyVar4}"
msg4=STRING|"{MyVar5}"
msgcount=STRING|"5"
begin=STRING|"1"
end=STRING|"5"
Name=STRING|"Desktop Alert"
defh=STRING|"1"
defw=STRING|"1"
duration=STRING|"5"
height=STRING|"76"
icon=STRING|"3"
kind=STRING|"0"
message=STRING|"{MyVar{cnt}}"
position=STRING|"3"
title=STRING|"MyVar{cnt}"
width=STRING|"330"
Alex007
Post by Alex007 »
Thank you
I am attaching my task but basically I just trying to use "set variable function" for existing array of integers, and getting an error "Illegal name of variable" .
CatID=INTEGER|0
ContinueOnError=INTEGER|1
ExternalName=STRING|"Task6"
ID=INTEGER|422428419
LocalVariables=STRING|"I=0,J=0,L=0,""SITES_IP=10.50.125.14, 192.168.115.254, 10.50.200.6, 10.50.160.1, 10.50.160.10, 10.50.80.10, 192.168.102.254, 192.168.177.254, 10.50.80.126, 192.168.117.254, 10.50.119.97, 10.50.119.206, 192.168.104.254, 172.16.147.254, 192.168.106.1, 10.50.80.74, 10.50.80.78, 192.168.101.254, 192.168.103.254, 172.16.135.8"",""SITES_SWEEP=0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0"""
Name=STRING|"Routers ping sweep test (imported)"
begin=STRING|"0"
end=STRING|"19"
ActionID=STRING|"A_INET_PING"
Name=STRING|"Ping {SITES_IP({I})}"
default=STRING|"-1"
host=STRING|"{SITES_IP({I})}"
timeout=STRING|"300"
variable=STRING|"PING"
operator=STRING|"5"
type=STRING|"1"
value1=STRING|"{PING}"
value2=STRING|"0"
Name=STRING|"Set variable ""SITES_SWEEP({I})"" with value ""1"""
varname=STRING|"SITES_SWEEP({I})"
varvalue=STRING|"1"
Name=STRING|"Increment variable ""I"""
incement=STRING|"1"
vaiable=STRING|"I"
Unfortunately you can't assign array element directly.
I recommend you to use indexed variables.
See my corrections below:
ExternalName=STRING|"Task253"
LocalVariables=STRING|"I=0,J=0,L=0,""SITES_IP=10.50.125.14, 192.168.115.254, 10.50.200.6, 10.50.160.1, 10.50.160.10, 10.50.80.10, 192.168.102.254, 192.168.177.254, 10.50.80.126, 192.168.117.254, 10.50.119.97, 10.50.119.206, 192.168.104.254, 172.16.147.254, 192.168.106.1, 10.50.80.74, 10.50.80.78, 192.168.101.254, 192.168.103.254, 172.16.135.8"",txt"
Name=STRING|"Routers ping sweep test"
Action14=FOLDER
Name=STRING|"Create local variable ""PING"" with value """""
varname=STRING|"PING"
begin=STRING|"0"
end=STRING|"19"
variable=STRING|"I"
Name=STRING|"Set variable ""TXT"" with value ""{txt}{Sites_IP({i})} -> {Sites_Sweep_{i}}{eol}"""
[Actions\Action12\Params]
varname=STRING|"TXT"
varvalue=STRING|"{txt}{Sites_IP({i})} -> {Sites_Sweep_{i}}{eol}"
[Actions\Action14]
Name=STRING|"Show ""{txt}"""
[Actions\Action14\Params]
msg0=STRING|"{txt}"
begin=STRING|"0"
end=STRING|"19"
default=STRING|"-1"
operator=STRING|"5"
type=STRING|"1"
value2=STRING|"0"
Name=STRING|"Create local variable ""SITES_SWEEP_{I}"" with value ""1"""
varname=STRING|"SITES_SWEEP_{I}"
varvalue=STRING|"1"
ActionID=STRING|"A_FLOW_ELSE"
Name=STRING|"Else"
Name=STRING|"Create local variable ""SITES_SWEEP_{I}"" with value ""0"""
varvalue=STRING|"0"
incement=STRING|"1"
vaiable=STRING|"I"
Alex007
Post by Alex007 »
Thank you
is that possible to add assign array element directly function in the future?
and thank you again, great software.
We'll discuss this, thank you
