csv edit
dbortunk
csv edit
Post by dbortunk »
I have a CSV file the has two fields on each line seperated by a comma. Some of the lines only have the comma starting the line and then the username. I want to remove all lines that start with a ,For example, user112345, user267891, user3, user423456, user5Should end up like12345, user267891, user323456, user5
csv edit
See the example below.
You can set the file name of CSV file at step #1
The task creates corrected CSV file with name {CSVFile}.new
CatID=INTEGER|2099193306
ExternalName=STRING|"Task17"
ID=INTEGER|2026014808
Name=STRING|"correct CSV"
Name=STRING|"Create local variable ""CSVFILE"" with value ""D:\Temp\test.csv"""
varname=STRING|"CSVFILE"
varvalue=STRING|"D:\Temp\test.csv"
Name=STRING|"Run ""Notepad.exe ""{csvfile}.new"""""
ifnonzero=STRING|"0"
params=STRING|"""{csvfile}.new"""
program=STRING|"Notepad.exe"
runas=STRING|"0"
wait=STRING|"0"
Name=STRING|"Create local variable ""CLINE"" with value """""
varname=STRING|"CLINE"
Name=STRING|"Create local variable ""NEWTEXT"" with value """""
varname=STRING|"NEWTEXT"
Name=STRING|"Text Loop"
destvar=STRING|"CLINE"
file=STRING|"{csvfile}"
linecount=STRING|"0"
sourcetext=STRING|"0"
operator=STRING|"8"
value1=STRING|"{cline(0)}"
Name=STRING|"Set variable ""NEWTEXT"" with value ""{newText}{cline}{EOL}"""
varvalue=STRING|"{newText}{cline}{EOL}"
Name=STRING|"Create text file {csvFile}.new"
fileexists=STRING|"0"
filname=STRING|"{csvFile}.new"
line0=STRING|"{newtext}"
suppress=STRING|"1"
[\Comment]
s1=I have a CSV file the has two fields on each line seperated by a comma.
s2=Some of the lines only have the comma starting the line and then the username. I want to remove all lines that start with a ,
s3=For example
s4=, user1
s5=12345, user2
s6=67891, user3
s7=, user4
s8=23456, user5
s9=Should end up like
s10=12345, user2
s11=67891, user3
s12=23456, user5
