copy files and subfolders
bruno.ucc
Post by bruno.ucc »
hi
I'm using robocopy for the first time I would like to help.
I need to copy a folder to folder B. folderA This folder
contains folders that are created every day. need to move
the older directories folders leaving only 6 months ahead.
Thks
Algorithm will be similar to this:
CatID=INTEGER|2099193306
ExternalName=STRING|"Task664"
ID=INTEGER|1845374931
Name=STRING|"Move old folders"
Name=STRING|"Create local variable ""FOLDERTOMOVE"" with value """""
varname=STRING|"FOLDERTOMOVE"
Name=STRING|"Create local variable ""DESTFOLDER"" with value """""
varname=STRING|"DESTFOLDER"
Name=STRING|"File Loop"
createmode=STRING|"4"
createormodified=STRING|"1"
date1=STRING|"20121122"
date2=STRING|"20121122"
destvar=STRING|"FOLDERTOMOVE"
DuringMinutes=STRING|"1"
file0=STRING|"C:\incoming\*.*"
OlderMonths=STRING|"6"
searchkind=STRING|"1"
subdirs=STRING|"0"
timesize=STRING|"0"
Name=STRING|"Set variable ""DESTFOLDER"" with value ""c:\dest\{ExtractFileName({FolderToMove})}"""
varvalue=STRING|"c:\dest\{ExtractFileName({FolderToMove})}"
ActionID=STRING|"A_FOLDER_SYNCHRONIZE"
Name=STRING|"Synchronize Folders"
clearro=STRING|"1"
details=STRING|"0"
exact=STRING|"0"
foder1=STRING|"{FolderToMove}"
foder2=STRING|"{DestFolder}"
hidden=STRING|"1"
howsync=STRING|"1"
includemask=STRING|"*.*"
subdir=STRING|"1"
system=STRING|"1"
Name=STRING|"Remove Nonempty Folder  ({foldertomove})"
deletefolder=STRING|"1"
folder=STRING|"{foldertomove}"
