Remove parts of text out of txt file
rice1973
Post by rice1973 »
Hello Oleg,
I made a filcompare with "FC" this is the syntax;
fc stock900.txt stock1000.txt > test.txt
this is the output
Comparing files stock900.txt and STOCK1000.TXT
***** stock900.txt
filiaal,sku,stock.qty,stock.is_in_stock
"1","010052270112","0","0"
"1","010059870113","0","0"
***** STOCK1000.TXT
"1","010052270112","1000","0"
Now i need to "cut" out of the test.txt file;
***** stock900.txt
***** STOCK1000.TXT
and the five stars at the end;
So only this is the result;
The number of lines in the fc result can vary.
In other words you need to keep only lines between
***** STOCK1000.TXT
and
Is this correct?
Look at this example, please:
CatID=INTEGER|1597096124
ExternalName=STRING|"Task34"
ID=INTEGER|1533792724
LocalVariables=STRING|"part"
Name=STRING|"Extract part of text"
Name=STRING|"RegExp Replace"
anchored=STRING|"0"
extended=STRING|"0"
line00000000=STRING|"Comparing files stock900.txt and STOCK1000.TXT "
line00000001=STRING|"***** stock900.txt "
line00000002=STRING|"filiaal,sku,stock.qty,stock.is_in_stock "
line00000003=STRING|"""1"",""010052270112"",""0"",""0"" "
line00000004=STRING|"""1"",""010059870113"",""0"",""0"" "
line00000005=STRING|"***** STOCK1000.TXT "
line00000006=STRING|"filiaal,sku,stock.qty,stock.is_in_stock "
line00000007=STRING|"""1"",""010052270112"",""1000"",""0"" "
line00000008=STRING|"""1"",""010059870113"",""0"",""0"" "
line00000009=STRING|"""1"",""010059870113"",""0"",""0"" "
line0000000A=STRING|"""1"",""010059870113"",""0"",""0"" "
line0000000B=STRING|"""1"",""010059870113"",""0"",""0"" "
line0000000C=STRING|"""1"",""010059870113"",""0"",""0"" "
line0000000D=STRING|"***** "
linecount=STRING|"14"
multiline=STRING|"1"
noautocapture=STRING|"0"
pattern=STRING|"(.+)(\*\*\*\*\* STOCK1000\.TXT[ ]*$)(.+)(\*\*\*\*\*[ ]*$)"
replacementcount=STRING|"0"
repline00000000=STRING|"$3"
replinecount=STRING|"1"
singleline=STRING|"1"
ungreedy=STRING|"0"
useexternal=STRING|"0"
variable=STRING|"part"
ActionID=STRING|"A_STR_TRIM"
Name=STRING|"STR Trim"
custom=STRING|"0"
eol=STRING|"1"
lead=STRING|"1"
source=STRING|"{part}"
spaces=STRING|"1"
tabs=STRING|"1"
trailing=STRING|"1"
Name=STRING|"Show ""{part}"""
msg0=STRING|"{part}"
anchored=STRING|"0"
extended=STRING|"0"
line00000000=STRING|"{part}"
pattern=STRING|"^filiaal.*$"
replinecount=STRING|"0"
singleline=STRING|"0"
ungreedy=STRING|"0"
custom=STRING|"0"
eol=STRING|"1"
lead=STRING|"1"
spaces=STRING|"1"
tabs=STRING|"1"
trailing=STRING|"1"
rice1973
Post by rice1973 »
Hello Oleg,
New problem, the file can also be like this;
***** stock900.txt
***** STOCK1000.TXT
***** stock900.txt
"1","010107750105","1","1"
"1","010090460113","0","0"
***** STOCK1000.TXT
"1","010090460113","500","0"
Thebn your solution does not work.. :(
rice1973
Post by rice1973 »
In the basic i need to compare 2 files.
But the FC command is not good for that...... :(
What strings do you want to extract?
I think all information lines in STOCK1000.TXT.
like this:
Correct?
I'll try to solve.
FC compares files and gives you differences as text with examples. What result do you want to obtain?
rice1973
Post by rice1973 »
"file 1" and "file 2"
After compare i only want to see the different lines with
the lines of "file 2" in it.
See improved example:
LocalVariables=STRING|"part,newtext,found"
Name=STRING|"Extract all parts of comparison"
ActionID=STRING|"A_REGEXP_LOOP"
Name=STRING|"RegExp Loop"
anchored=STRING|"0"
extended=STRING|"0"
line00000009=STRING|"***** "
line0000000B=STRING|"***** stock900.txt "
line0000000C=STRING|"""1"",""010107750105"",""1"",""1"" "
line0000000D=STRING|"""1"",""010090460113"",""0"",""0"" "
line0000000F=STRING|"***** STOCK1000.TXT "
line00000010=STRING|"""1"",""010107750105"",""1"",""1"" "
line00000011=STRING|"""1"",""010090460113"",""500"",""0"" "
line00000013=STRING|"***** "
line00000016=STRING|"***** stock900.txt "
line00000017=STRING|"""1"",""010107750105"",""1"",""1"" "
line00000018=STRING|"""1"",""010090460113"",""0"",""0"" "
line0000001A=STRING|"***** STOCK1000.TXT "
line0000001B=STRING|"""1"",""010107750105"",""1"",""1"" "
line0000001C=STRING|"""1"",""010090460113"",""500"",""2"" "
line0000001D=STRING|"""1"",""010107750105"",""1"",""3"" "
line0000001E=STRING|"""1"",""010090460113"",""500"",""4"" "
line0000001F=STRING|"""1"",""010107750105"",""1"",""5"" "
line00000020=STRING|"""1"",""010090460113"",""500"",""5"" "
line00000022=STRING|"***** "
linecount=STRING|"35"
pattern=STRING|"\*\*\*\*\* STOCK1000\.TXT[ ]*$(.+)\*\*\*\*\*[ ]*$"
savelengths=STRING|"0"
saveoffsets=STRING|"0"
ungreedy=STRING|"1"
Name=STRING|"Set variable ""NEWTEXT"" with value ""{NewText}{part}{eol}"""
varname=STRING|"NEWTEXT"
varvalue=STRING|"{NewText}{part}{eol}"
Name=STRING|"Show ""{NewText}"""
[Actions\Action12\Params]
msg0=STRING|"{NewText}"
custom=STRING|"0"
eol=STRING|"1"
lead=STRING|"1"
source=STRING|"{part(1)}"
spaces=STRING|"1"
tabs=STRING|"1"
trailing=STRING|"1"
Enabled=INTEGER|0
Name=STRING|"RegExp Match"
anchored=STRING|"0"
extended=STRING|"0"
pattern=STRING|"^filiaal"
savesubexpression=STRING|"0"
subexpressionpos=STRING|"0"
ungreedy=STRING|"0"
variable=STRING|"found"
value1=STRING|"{found}"
anchored=STRING|"0"
extended=STRING|"0"
pattern=STRING|"(filiaal.*$)(.+)"
ungreedy=STRING|"1"
custom=STRING|"0"
eol=STRING|"1"
lead=STRING|"1"
spaces=STRING|"1"
tabs=STRING|"1"
trailing=STRING|"1"
Enabled=INTEGER|0
rice1973
Post by rice1973 »
Hello Oleg,
Just send you an email on info@robotask.com with the files
to explain.
sender: info@mjbprojects.nl
