Logoff Robotask.exe Goes Away?
charris317
Post by charris317 »
Testing the software and made some tasks but when I logged off the box the Robotask.exe went away and tasks stopped triggering.
Am I missing a setting to make it run the tasks when logged off?
Running on Windows 2008 server.
Thanks!
When you log-off then Windows closes your session and stops all user applications. RoboTask application will be stopped too.
If you want RoboTask to continue to work you should use RoboTask as system service.
Read here, please, how to install RoboTask service.
Also read related chapters.
charris317
Thanks, that worked.
Installed Service
Copied my tasks to C - Program Files - Robotask - Tasks and then restarted the service and tasks are running when logged off.
