Loop through folders
deesloop
Post by deesloop »
I have 5 folders
Folder1, foledr 2
Folder 3, Folder 4 & Folder 5
What I want to do is check that at least 1 file exists in each of these folders and if so run a script.
Oce the script is run then send an email and delete all files from the 5 folders.
I had thought of using count number of files and if the value was 5 or more then goto the next part of the script
However that doesnt work as folder 2 could have 2 files, or folder 3 could have 17
I'm looking for an
ANd f1count>1 and f2count >1 and f3 cont >1 and f4count >1 sort of thing.
Any ideas - apart from a 5 level if then...
Thanks
See the example below:
CatID=INTEGER|1981581740
ExternalName=STRING|"Task77"
ID=INTEGER|568688620
LocalVariables=STRING|"flag"
Name=STRING|"Check files in 5 folders"
Action14=FOLDER
Action15=FOLDER
Action16=FOLDER
Action17=FOLDER
Action18=FOLDER
Action19=FOLDER
Action20=FOLDER
Action21=FOLDER
Action22=FOLDER
Name=STRING|"Set variable ""FLAG"" with value ""0"""
varname=STRING|"FLAG"
varvalue=STRING|"0"
value1=STRING|"{FileExists(c:\folder4\*.txt)}"
Name=STRING|"Increment variable ""flag"""
[Actions\Action12\Params]
incement=STRING|"1"
vaiable=STRING|"flag"
[Actions\Action14]
[Actions\Action14\Params]
value1=STRING|"{FileExists(c:\folder5\*.txt)}"
[Actions\Action15]
[Actions\Action15\Params]
incement=STRING|"1"
[Actions\Action16]
[Actions\Action17]
Name=STRING|"//actions here"
[Actions\Action17\Params]
comment=STRING|"actions here"
[Actions\Action18]
[Actions\Action18\Params]
type=STRING|"1"
value1=STRING|"{flag}"
value2=STRING|"5"
[Actions\Action19]
Name=STRING|"Show ""FLAG={flag}"""
[Actions\Action19\Params]
msg0=STRING|"FLAG={flag}"
msg1=STRING|"Files are exists in each folder"
msgcount=STRING|"2"
value1=STRING|"{FileExists(c:\folder1\*.txt)}"
[Actions\Action20]
ActionID=STRING|"A_FLOW_ELSE"
Name=STRING|"Else"
[Actions\Action21]
[Actions\Action21\Params]
icon=STRING|"0"
[Actions\Action22]
incement=STRING|"1"
value1=STRING|"{FileExists(c:\folder2\*.txt)}"
incement=STRING|"1"
value1=STRING|"{FileExists(c:\folder3\*.txt)}"
incement=STRING|"1"
