How to custom rename
skazmi12
Post by skazmi12 »
I am using "Rename File" action to rename following
extracted zip file:
abcdefghijk.zip.txt, How can I remove .zip from the new
file name?
You can do this by using STR Replace action (for example).
See the example below:
CatID=INTEGER|1380072790
ExternalName=STRING|"Task1196"
ID=INTEGER|766273464
LocalVariables=STRING|"FileName,NewFileName"
Name=STRING|"remove ZIP from file name"
Name=STRING|"Set variable ""FILENAME"" with value ""abcdefghijk.zip.txt"""
varname=STRING|"FILENAME"
varvalue=STRING|"abcdefghijk.zip.txt"
Name=STRING|"STR Replace"
mode=STRING|"0"
replacement=STRING|"."
source=STRING|"{FileName}"
substring=STRING|".zip."
variable=STRING|"NewFileName"
Name=STRING|"Show ""Old name: {FileName}"""
msg0=STRING|"Old name: {FileName}"
msg1=STRING|"New name: {NewFileName}"
msgcount=STRING|"2"
Enabled=INTEGER|0
Name=STRING|"Rename File"
file0=STRING|"{FileName}"
ifexists=STRING|"0"
mask=STRING|"{NewFileName}"
subdirs=STRING|"0"
