Quotes in WebForm text
historian
Post by historian »
So I've got a list of keywords to put in to webform, however when I loop through the list if the keyword(s) if there is a space it adds quotes.
For example: If the variable is 'Bob Barker' the form is populated with "Bob Barker" with the quotes. However if it is just 'Bob' then it is Bob with no quotes.
How do I clear those quotes?
Send me your task please. It seems the problem is in it.
historian
Post by historian »
CatID=INTEGER|0
ExternalName=STRING|"Task1"
ID=INTEGER|266310893
Name=STRING|"Keyword import"
Name=STRING|"Text Loop"
destvar=STRING|"{KEYWORD}"
line0=STRING|"Agile Development"
line1=STRING|"Analysis"
linecount=STRING|"2"
sourcetext=STRING|"1"
ActionID=STRING|"A_WD_FILLFORM"
Name=STRING|"Fill Web Form"
address=STRING|"https://192.168.1.22/admin/content/taxonomy/41/add/term"
autodownload=STRING|"0"
autologon=STRING|"0"
form=STRING|"0"
keep=STRING|"0"
overwrite=STRING|"0"
param0000=STRING|"edit-name,0,Edit,{KEYWORD}"
paramscount=STRING|"1"
submit=STRING|"1"
Thank you. we'll investigate the problem.
Unfortunately it was a bug.
We have fixed it now.
Download and install this patch please.
