Error sending email
thjmcd
Error sending email
Post by thjmcd »
Hi
I have two send email tasks,
Both are setup the same,
however I receive an error with one of them:
E: 07/06/2012 11:25:13: Error occurred: 5.7.1
<developers@******.com>: Relay access denied<CR><LF>
Both tasks are to the same email group and use the same
host/port.
Any ideas as to where the access is denied to?
Thanks
Awgeewhiz
Error sending email
Post by Awgeewhiz »
Basically it's a spam filter.
http://www.penpublishing.com/support/em ... nderstandi ngemailerrors/default.aspx#554
Error sending email
Also it may be settings of SMTP server. Probably sender's email address is incorrect or another restrictions.
Usually SMTP server has some relaying rules. If the message corresponds to those rules then SMTP relays it.
