Incorrect syntax near ’GO’
thjmcd
Post by thjmcd »
I am trying to run a SQL query using "GO".
When I run the task in Robotask I get an error returned -
E: 05/01/2012 11:38:09: Error has occurred: Incorrect
syntax near 'GO'
The Query is correct as when I run it in SQL the script
preforms as expected.
Is there an alternative to GO I can use in robotask?
Thomas
Send full text of SQL query that you use.
I'm afraid that this error message you receive from database engine.
BTW: what kind of database do you use?
thjmcd
Post by thjmcd »
USE MASTER
GO
DROP DATABASE DB_Name
GO
the db is SQL2008
Thanks
Thomas
This is a batch of SQL expressions. "SQL query" action is designed for use single expression like:
INSERT
DELETE
UPDATE
CALL
etc.
For example Oracle database allows to use simple trick - run dynamic procedure.
Like this:
BEGIN
   DECLARE CNT;
   select count(*) from table1 into CNT;
   update table2 set field1=cnt where id = 1;
END
This is not a batch, this is single expression.
But I'm afraid that many databases have no such feature.
We'll add the SQL Batch action in future.
