The question how to delete email
john.k
Post by john.k »
Tell me how to remove it from the gmail email with a
certain subject?
Use "POP3 Mail loop" action
Algorithm will be approx this:
POP3 Open
POP3 Mail Loop
   if subj = 'Some string' then
      POP3 Delete Email // by order num
   endif
end loop
Do you need an example?
john.k
Post by john.k »
Oleg wrote: Do you need an example?
Yes, please.
See below.
Of course you need change mail server, authentication parameters, and condition to yours.
CatID=INTEGER|335077256
ExternalName=STRING|"Task1121"
ID=INTEGER|948370511
LocalVariables=STRING|"MsgNum,MsgSubj"
Name=STRING|"Delete email by subject"
ActionID=STRING|"A_EMAIL_OPEN"
Name=STRING|"POP3 Open"
host=STRING|"mail.domain.com"
password=STRING|"4438845245462874500344480"
port=STRING|"110"
SSL=STRING|"0"
user=STRING|"user"
ActionID=STRING|"A_EMAIL_LOOP"
Name=STRING|"POP3 Mail Loop"
number=STRING|"MsgNum"
subj=STRING|"MsgSubj"
usecc=STRING|"0"
usedate=STRING|"0"
usefrom=STRING|"0"
usesize=STRING|"0"
usesubj=STRING|"1"
useto=STRING|"0"
value1=STRING|"{MsgSubj}"
value2=STRING|"Some string"
ActionID=STRING|"A_EMAIL_DELETE"
Name=STRING|"POP3 Delete Email"
num=STRING|"{MsgNum}"
john.k
Post by john.k »
All do, but the subject gets data of this type:
=?UTF-8?B?0J3QsCDRgdCw0LnRgtC1IHd3?=.Uxty. =?UTF-8?B?
a3og0LTQvtCx0LDQstC70LXQvdGLINC90L7QstGL0LUg0YTQuNC70YzQvNG
L?=
john.k
Post by john.k »
How to get a string of normal form?
It seems the program have problems with UTF-8 messages with non-latin characters.
