Cancel Task?
arrowmed
Cancel Task?
Post by arrowmed »
Modified the "find latest/newest file" task so that it sends an email when a file is detected.
There are several times when I DO NOT want an email sent, but when the folder select window comes up and I click on cancel, the task is not being cancelled and an email is being sent with a "bogus" file listing from the temp directory.
How do I cancel a task when it starts?
Thanks in advance.
Jim
Cancel Task?
Try to use "Question dialog" coupled with "If then" action. In question dialog you ask user: "Do you want to send email?". And if he clicked Yes, task send a message.
Question dialog have autochoice (with timeout), therefore you don't need press any button necessarily.
arrowmed
Cancel Task?
Post by arrowmed »
Thank you!
