Zip Extract with password Variable?
rknight10
Post by rknight10 »
I have a zip file with a password. I can add the Zip Extract step with the password entered and it will extract the files correctly.
If I use a variable populated from an input dialog to populate the password field it does not work.
Can anyone confirm that using a variable for a Zip password works?
Thanks in advance for looking into this,
Rob
rknight10
Post by rknight10 »
Just bumping this as I could still use help on it.
Anyone trying to unzip files with a password that changes? Maybe there is a better way to accomplish this?
Thanks.
You can set all passwords in actions explicitly only.
We'll add the possibility of using variables in passwords later.
