Check mail and download attached file
Gekseppe
Post by Gekseppe »
Hi.
I get struck in writing a task with the following purposes:
1. Check if there are new e-mail;
2. If there are new mails then download attached file in a folder;
3. Delete e-mail.
It seems easy but, the way I did gave the following problems:
1. if there are no mails task falls in error;
2. If there are more than one mail task falls in error due to "invalid number of message".
Please could you provide a sample ?
Thank you and regards,
gekseppe
See the example below:
CatID=INTEGER|1897123812
ExternalName=STRING|"Task19"
ID=INTEGER|154598682
LocalVariables=STRING|"cnt,sz"
Name=STRING|"Download messages from POP3"
ToLog=INTEGER|1
ActionID=STRING|"A_EMAIL_OPEN"
Name=STRING|"POP3 Open"
host=STRING|"MyDomail.com"
password=STRING|"4438845245462874500344480"
port=STRING|"110"
SSL=STRING|"0"
user=STRING|"username"
ActionID=STRING|"A_EMAIL_COUNT"
Name=STRING|"POP3 Messages Count"
amount=STRING|"1"
amountvar=STRING|"cnt"
size=STRING|"1"
sizevar=STRING|"sz"
message=STRING|"{cnt} messages. Total size {sz}"
ActionID=STRING|"A_EMAIL_LOOP"
Name=STRING|"POP3 Mail Loop"
cc=STRING|"mes_cc"
date=STRING|"mes_date"
from=STRING|"mes_from"
number=STRING|"mes_num"
size=STRING|"mes_size"
subj=STRING|"mes_subj"
to=STRING|"mes_to"
usecc=STRING|"0"
usedate=STRING|"0"
usefrom=STRING|"0"
usesize=STRING|"0"
usesubj=STRING|"0"
useto=STRING|"0"
message=STRING|"Downloading and Removing {mes_num} message "
ActionID=STRING|"E_EMAIL_DOWNLOAD"
Name=STRING|"POP3 Download Email"
extract=STRING|"0"
num=STRING|"{mes_num}"
overwrite=STRING|"0"
 savetofile=STRING|"c:\incoming\{Year}{MonthNo}{Day}{Hours}{M inutes}{Seconds}{mSeconds}.eml"
ActionID=STRING|"A_EMAIL_DELETE"
Name=STRING|"POP3 Delete Email"
message=STRING|"{cnt} messages has been downloaded and removed from server"
id=STRING|"KAQ1D5UB"
interval=STRING|"3600"
Also you can check the existence of messages on server by using Check for Email action.
