How do I set up service?
JAdams
Post by JAdams »
I have RoboTask set up as a service and it works fine while I am logged into that service, via Remote Desktop Services. But the tasks I have set up will not run once I logout. When I log back in, then they run. Do I have it set up wrong, or is this a limitation of the software?
See other topics, please, with similar questions: here (#1), here (#2) and here (#3)
Probably it will help you.
JAdams
Post by JAdams »
In one of your other replies you stated:
Suggestion:
In order to configure RoboTask service at terminal session, you can do the following:
1. Specify in "RoboTask-desktop" (in your profile) same tasks folder what in "RoboTask-Service". Menu "Opton | Settings".
2. Now you can configure service from your RoboTask-desktop copy
- Stop RoboTask service
- Configure some tasks
- Start RoboTask service
How do I get to the RoboTask-desktop in my profile? What directory on the server is that? And what file? How would I then get to the RoboTask-Service to change the Menu Option Settings? What are its default settings? Couldn't I go into the standalone program and change its settings to match the Service defaults? Thanks.
