wrong logs
AnkitaHundal
wrong logs
Post by AnkitaHundal »
Robotask shows a task to have run successfully even when
it doesn't.
Example: I have set up robotask to start and stop a
respective program every workday morning and evening
respectively.
Now, even when the task hasnt even got initiated,
Robotask shows the task to have run successfully. i ahve
checked the scheduler, and the setup is correct.
It also gets fixed on certain actions on particular days,
however running the same task fine the other day.
Please help.
Thanks
wrong logs
What do you see in the task log?
System log shows that trigger have tried to start the task. But this do not garantee that the task will work as you wish.
AnkitaHundal
wrong logs
The logs showed the following to me even when the task
was not completed successfully. What are the logs based
on? the task was not even initiated - i was monitoring it
I: 01/05/2011 2:45:00 PM: Executing "Restore window "Auto
Ticket Generator - [ESR Alerts]""
I: 01/05/2011 2:45:01 PM: 1 windows processed
I: 01/05/2011 2:45:01 PM: Executing "Delay 800 ms"
I: 01/05/2011 2:45:02 PM: Executing "Send keys to "Auto
I: 01/05/2011 2:45:03 PM: Executing "Minimize window
"Auto Ticket Generator - [ESR Alerts]""
I: 01/05/2011 2:45:03 PM: 1 windows processed
I: 01/05/2011 2:45:03 PM: Task executed successfully
AnkitaHundal
wrong logs
This leads to the issue that why does the task doesn't run
even on programming the scheduler for a specific time?
Does Robotask have any sleep mode programming by any
chance?
wrong logs
Do you want to say that the task wasn't started by scheduler at specified time?
Are you sure that computer worked at specified time? If it was in "sleep" or "hibernate" mode, the task can't be started anyway.
AnkitaHundal
wrong logs
Hi there,
Yes the task did not start at the specified time. Also,
certain tasks go through fine when initiated manually, but
get stuck when the scheduler initiates them.
Its an erratic behavior with some tasks.
The system never shuts down unless power cycled manually.
Also, has been set to never hibernate.
I am still checking in-case there are any services or
applications which might be interfering but haven't found
anything yet.
Thanks
AnkitaHundal
wrong logs
I tried running Robotask as the sole application running
on the system, and it still gave me the same logs.......
"task run successfully" even when it did not!
Any suggestions.. updates.. input?
Thanks
wrong logs
Send me the task, log of the task, and system log to oleg (at) robotask.com.
