;* RoboTask Task file *
;* Do not edit! *
CatID=INTEGER|0
ExternalName=STRING|"Task7"
ID=INTEGER|782740870
Name=STRING|"Find the latest/newest modified file in a folder."
Name=STRING|"Create variable ""LATEST_DATETIME"" with value ""01/01/1890 12:00:00"""
varname=STRING|"LATEST_DATETIME"
varvalue=STRING|"01/01/1890 12:00:00"
Name=STRING|"File Loop"
date1=STRING|"20040520"
date2=STRING|"20040520"
destvar=STRING|"CURRENT_FILENAME"
file0=STRING|"C:\WINDOWS\*.*"
subdirs=STRING|"1"
timesize=STRING|"1"
timevar=STRING|"CURRENT_DATETIME"
WithoutPath=STRING|"1"
operator=STRING|"3"
type=STRING|"2"
value1=STRING|"{CURRENT_DATETIME}"
value2=STRING|"{LATEST_DATETIME}"
Name=STRING|"Set variable ""LATEST_FILENAME"" with value ""{CURRENT_FILENAME}"""
varname=STRING|"LATEST_FILENAME"
varvalue=STRING|"{CURRENT_FILENAME}"
Name=STRING|"Set variable ""LATEST_DATETIME"" with value ""{CURRENT_DATETIME}"""
varvalue=STRING|"{CURRENT_DATETIME}"
Name=STRING|"Show ""The latest/newest file in ( C:\WINDOWS ) is ( {LATEST_FILENAME} ) modified ( {LATEST_DATETIME} )."""
msg0=STRING|"The latest/newest file in ( C:\WINDOWS ) is ( {LATEST_FILENAME} ) modified ( {LATEST_DATETIME} )."
Find the latest modified file in a folder
