Rezise
rice1973
Re: Rezise
Post by rice1973 »
Hi Oleg,
I alos use Image Magick and i want to resize one folder at a time, but the foldername is a variable.
Example; rootfolder is 3dmap , first subfolder is 360, second subfolder, containing the images is for example 287.10.72. But this foldername has to be extracted to use in Robotask. .
Because i cannot set a "hard" foldername. Can you help me?
Robotask rules! :)
Re: Rezise
I'm afraid that I don't understand your goal completely...
If you don't know file (or folder) names beforehand you always can retrieve them by using of "Search for Files" action
Also you can form the list of files or folders in the loop. See "File Loop"
rice1973
Re: Rezise
Post by rice1973 »
Hello Oleg,
Solved. I iused "search for files".
Robotask rules! :)
