Action "Login to network share / Map network drive" does not connect nor disconnect
jan
Re: Check the connection to the network drive
Post by jan »
on my desktop computer the "Windows Wachter" worked, but on a virtual machine the second window, which appeared 30 seconds later than the first window, was not processed. I will follow up and give feedback if necessary.
Thanks so far, Ján
...but on a virtual machine the second window...
Your virtual machine is a "black box" for your host computer. Generally speaking, it is a different computer. RoboTask cannot detect windows in the virtual machine from the host computer.
To make the window watcher trigger work, you need to install RoboTask on your virtual machine
jan
Post by jan »
Hello Oleg,
I'm just a beginner, sorry. I tried to disconnect the network drive from one task and connect it with another task. It doesn't work. Here is the code from disconnecting. Robotask says task successfully completed, but the drive is still there! I do not understand. 3 error messages appear when connecting:
E: 28.01.2025 15:26:06: System error 1219 occurred.
E: 28.01.2025 15:26:06: Multiple connections to a server or a shared resource from the same user using multiple user names are not permitted. Disconnect all previous connections to the server or shared resource and try again.
E: 28.01.2025 15:26:06: There was an error. Step 1 (Map "\\192.168.178.111\SK01" as "R:").
I attach both codes one below the other. Maybe you can help?
CatID=INTEGER|0
ExternalName=STRING|"Task1"
ID=INTEGER|-955131315
Name=STRING|"Disconnect drive"
StepPause=INTEGER|0
ActionID=STRING|"A_LOGIN_MAP_SHARE"
Name=STRING|"Disconnect from ""\\192.168.178.111\SK01"""
drive=STRING|"F:"
mapdrive=STRING|"0"
mode=STRING|"1"
sharename=STRING|"\\192.168.178.111\SK01"
CatID=INTEGER|0
ExternalName=STRING|"Task7"
ID=INTEGER|975365124
Name=STRING|"Connect drive"
StepPause=INTEGER|0
Name=STRING|"Map ""\\192.168.178.111\SK01"" as ""R:"""
drive=STRING|"R:"
mapdrive=STRING|"1"
mode=STRING|"0"
username=STRING|"jan.bluhm"
Do you see any warnings in the log?
If network drive is already mapped as R: you must disconnect R: (not \\192.168.178.111\SK01)
jan
Post by jan »
Hi Oleg, I have listed the error messages in my last post
As I said, I am trying to check whether a drive, this is a network drive, exists (I can see this from the drive letter in Explorer) and whether it is accessible (I can check this by double-clicking so that the drive opens). If it is not available in Explorer, a connection to the network drive should be established. In other words, the drive letter must appear in Explorer.
