Clear Log action
OldGeek
Re: Clear Log action
Post by OldGeek »
felipe wrote: Tue Jun 25, 2024 12:10 am I didn't add "Restart Robotask"
It is up to you when this will be done.
Thank You for sharing. I'm sure I'll use it.
OldGeek
Post by OldGeek »
I'm working a version 2 of your idea. When I've tested it more, I'll post it here.
adhunkins
Post by adhunkins »
This is a great workaround.
But I think there are certain functions that would be cleaner to have built into RoboTask.
There are many functions that you "could" patch for RoboTask using RoboTask. For example, RoboTask could have NO HOTKEYS (not even copy/paste) and you would have to build RoboTask hotkey triggers/tasks for any/all functions you wanted to activate with the keyboard rather than a mouse click. But why? I think the app should have common/useful actions built into the product even if it's theoretically possible to build a patch in RoboTask. ...just my 2 cents.
OldGeek
Post by OldGeek »
Attached is my take on Clearing a log file; You select the specific logs and how many days of data to keep.
CatID=INTEGER|1332952927
ContinueOnError=INTEGER|2
ExternalName=STRING|"Task2"
ID=INTEGER|747979658
Name=STRING|"Delete Temp Files Older Than 30 Days"
StepPause=INTEGER|0
ToLog=INTEGER|1
Action14=FOLDER
Action15=FOLDER
Action16=FOLDER
Action17=FOLDER
Action18=FOLDER
Action19=FOLDER
Action20=FOLDER
Action21=FOLDER
Action22=FOLDER
Action23=FOLDER
Action24=FOLDER
Action25=FOLDER
Action26=FOLDER
Action27=FOLDER
Action28=FOLDER
Action29=FOLDER
Action30=FOLDER
Action31=FOLDER
Action32=FOLDER
Action33=FOLDER
Action34=FOLDER
Action35=FOLDER
Action36=FOLDER
Action37=FOLDER
Action38=FOLDER
Action39=FOLDER
message=STRING|"====== [Start Task:] Delete Temp Files Old Than 30 Days"
Name=STRING|"Create local variable ""Blanks"" with value """""
_rt_variables_produced=STRING|"Blanks"
linecount=STRING|"0"
varname=STRING|"Blanks"
Name=STRING|"Simple Loop"
_rt_variables_produced=STRING|"nCount"
begin=STRING|"1"
end=STRING|"50"
step=STRING|"1"
variable=STRING|"nCount"
ActionID=STRING|"A_STR_INSERT"
Name=STRING|"STR Insert"
[Actions\Action12\Params]
insert=STRING|" "
pos=STRING|"1"
source=STRING|"{Blanks}"
variable=STRING|"Blanks"
[Actions\Action14]
Name=STRING|"//Search for old temp files"
[Actions\Action14\Params]
comment=STRING|"Search for old temp files"
[Actions\Action15]
Enabled=INTEGER|0
[Actions\Action15\Params]
message=STRING|"[STEP: 15] Searching for Old Temp Files"
[Actions\Action16]
Name=STRING|"File Loop"
[Actions\Action16\Params]
_rt_variables_produced=STRING|"FileDateTime,FileToDelete"
createmode=STRING|"5"
createormodified=STRING|"1"
date1=STRING|"20040614"
date2=STRING|"20040614"
destvar=STRING|"FileToDelete"
DuringMinutes=STRING|"1"
file0=STRING|"{TempDir}\*.*"
OlderDays=STRING|"30"
searchkind=STRING|"0"
sort=STRING|"0"
sortby=STRING|"0"
sortorder=STRING|"0"
subdirs=STRING|"1"
timesize=STRING|"1"
timevar=STRING|"FileDateTime"
[Actions\Action17]
Name=STRING|"Increment variable ""FileCount"""
[Actions\Action17\Params]
incement=STRING|"1"
vaiable=STRING|"FileCount"
[Actions\Action18]
Name=STRING|"Increment variable ""FileSize"""
[Actions\Action18\Params]
incement=STRING|"{FileSize({FileToDelete})}"
vaiable=STRING|"FileSize"
[Actions\Action19]
Name=STRING|"Set variable ""strTemp"" with value """""
[Actions\Action19\Params]
_rt_variables_produced=STRING|"strTemp"
varname=STRING|"strTemp"
message=STRING|"[STEP: 2] Today - 30 Days: {DateIncDays(-30)}"
[Actions\Action20]
Name=STRING|"Set variable ""strTemp"" with value ""{FileToDelete}{Blanks}"""
[Actions\Action20\Params]
varvalue=STRING|"{FileToDelete}{Blanks}"
[Actions\Action21]
Name=STRING|"STR Extract"
[Actions\Action21\Params]
amount=STRING|"50"
from=STRING|"1"
source=STRING|"{strTemp}"
variable=STRING|"strTemp"
[Actions\Action22]
[Actions\Action22\Params]
message=STRING|"[STEP: 22] Deleting File: {strTemp} - {FileDateTime}"
[Actions\Action23]
Name=STRING|"Delete File"
[Actions\Action23\Params]
Count=STRING|"1"
deletedirs=STRING|"0"
deletereadonly=STRING|"0"
file0=STRING|"{FileToDelete}"
hidden=STRING|"1"
subdir=STRING|"0"
system=STRING|"1"
ToRecycleBin=STRING|"1"
[Actions\Action24]
[Actions\Action25]
Name=STRING|"//Delete Empty Folders"
[Actions\Action25\Params]
comment=STRING|"Delete Empty Folders"
[Actions\Action26]
Enabled=INTEGER|0
[Actions\Action26\Params]
message=STRING|"[STEP: 26] Searching for Empty Folders Older Than 30 Days"
[Actions\Action27]
[Actions\Action27\Params]
_rt_variables_produced=STRING|"EmptyFolder,FileDateTime"
date1=STRING|"20091201"
date2=STRING|"20091201"
destvar=STRING|"EmptyFolder"
searchkind=STRING|"1"
sort=STRING|"0"
sortby=STRING|"0"
subdirs=STRING|"0"
timesize=STRING|"1"
[Actions\Action28]
[Actions\Action28\Params]
type=STRING|"1"
value1=STRING|"{FilesCount({EmptyFolder})}"
value2=STRING|"0"
[Actions\Action29]
[Actions\Action29\Params]
Name=STRING|"Create local variable ""FileCount"" with value ""0"""
_rt_variables_produced=STRING|"FileCount"
varname=STRING|"FileCount"
varvalue=STRING|"0"
[Actions\Action30]
Name=STRING|"Set variable ""strTemp"" with value ""{EmptyFolder}{Blanks}"""
[Actions\Action30\Params]
varvalue=STRING|"{EmptyFolder}{Blanks}"
[Actions\Action31]
[Actions\Action31\Params]
amount=STRING|"50"
from=STRING|"1"
[Actions\Action32]
[Actions\Action32\Params]
message=STRING|"[STEP: 32] Deleting Empty Folder: {strTemp} - {FileDateTime}"
[Actions\Action33]
Name=STRING|"Remove Empty Folder ({EmptyFolder})"
[Actions\Action33\Params]
deletefolder=STRING|"0"
folder=STRING|"{EmptyFolder}"
[Actions\Action34]
[Actions\Action35]
[Actions\Action36]
[Actions\Action36\Params]
operator=STRING|"3"
type=STRING|"1"
value1=STRING|"{FileCount}"
value2=STRING|"0"
[Actions\Action37]
[Actions\Action37\Params]
message=STRING|"[STEP: 38] Done, {FileCount} Files Deleted, ({FileSize} bytes)."
[Actions\Action38]
[Actions\Action39]
[Actions\Action39\Params]
message=STRING|"====== [End Task:] Delete Temp Files Old Than 30 Days"
Name=STRING|"Create local variable ""FileSize"" with value ""0"""
_rt_variables_produced=STRING|"FileSize"
varname=STRING|"FileSize"
varvalue=STRING|"0"
Name=STRING|"Create local variable ""FileToDelete"" with value """""
_rt_variables_produced=STRING|"FileToDelete"
varname=STRING|"FileToDelete"
Name=STRING|"Create local variable ""FileDateTime"" with value """""
_rt_variables_produced=STRING|"FileDateTime"
varname=STRING|"FileDateTime"
Name=STRING|"Create local variable ""EmptyFolder"" with value """""
_rt_variables_produced=STRING|"EmptyFolder"
varname=STRING|"EmptyFolder"
Name=STRING|"Create local variable ""strTemp"" with value """""
Name=STRING|"Create local variable ""nCount"" with value ""0"""
varname=STRING|"nCount"
varvalue=STRING|"0"
Name=STRING|"Scheduler(6/16/2023 12:00:00 PM)"
UniqueID=INTEGER|-2067565362
periodicity=STRING|"0"
startdate=STRING|"45460"
time0=STRING|"25320000"
timecount=STRING|"1"
wakeup=STRING|"0"
adhunkins
Post by adhunkins »
It's in the latest update!! Yay! :D Thank you, @Oleg!!
