Posts: 3310 Joined: Thu Jan 01, 1970 1:00 am
Post
by Oleg » Tue Aug 08, 2023 2:15 pm
Look at the example below
You should set file size to some variable in the "loop" step
Then you can compare file size with your value and do neccesary actions.
CatID=INTEGER|1163085779
ExternalName=STRING|"Task1040"
ID=INTEGER|935581320
Name=STRING|"skip files more 255 bytes"
StepPause=INTEGER|0
ToLog=INTEGER|2
Name=STRING|"Set variable ""folder"" with value ""d:\incoming"""
_rt_variables_produced=STRING|"folder"
varname=STRING|"folder"
varvalue=STRING|"d:\incoming"
Name=STRING|"File Loop"
_rt_variables_produced=STRING|"FileName,sz"
date1=STRING|"20230808"
date2=STRING|"20230808"
destvar=STRING|"FileName"
DuringMinutes=STRING|"1"
file0=STRING|"{folder}\*.*"
savesize=STRING|"1"
savevar=STRING|"sz"
searchkind=STRING|"0"
sort=STRING|"0"
sortby=STRING|"0"
sortorder=STRING|"0"
subdirs=STRING|"0"
timesize=STRING|"0"
operator=STRING|"3"
type=STRING|"1"
value1=STRING|"{sz}"
value2=STRING|"255"
message=STRING|"File {FileName} skipped (more than 255 bytes)"
type=STRING|"1"
ActionID=STRING|"A_FLOW_ELSE"
Name=STRING|"Else"
message=STRING|"File {FileName} must be processed"
Danarlidge
Posts: 8 Joined: Thu Apr 13, 2023 9:45 am
Post
by Danarlidge » Tue Aug 29, 2023 10:23 am
Hi Oleg,
I hope all is well.
Thank you for the below. Is this possible with the file path length, not the file size?
https://learn.microsoft.com/en-us/windo ... s=registry
Kind Regards,
Dan Arlidge
Oleg wrote: ↑ Tue Aug 08, 2023 2:15 pm
StepPause=INTEGER|0
ToLog=INTEGER|2
savesize=STRING|"1"
savevar=STRING|"sz"
sort=STRING|"0"
sortby=STRING|"0"
subdirs=STRING|"0"
timesize=STRING|"0"
operator=STRING|"3"
type=STRING|"1"
value2=STRING|"255"
type=STRING|"1"
Name=STRING|"Else"
Zac
Posts: 18 Joined: Wed Feb 22, 2023 5:14 pm
Post
by Zac » Tue Jan 09, 2024 6:00 pm
Solution for skipping files of 255 or more, what you can do is create an variable holder that we will call "VarLeng" and use the clipboard to copy the file address or whatever your trying to find the length of and then in an IF statement, choose the number type and in the first box type "{StrLength({VarLeng})}" and in the second box say 255 and then choose the arithmetic operator you want to use whether > or >= and then put your steps to complete if true or if it's false skip and move onto the next one. Apologies I didn't post the task for completing this like Oleg but hopes it helps! Also the {StrLenght()} is a system variables in the text and string category if you want to look at the other types of variable helpers there are!
