FTP to Mainframe (Z/OS)
Re: FTP to Mainframe (Z/OS)
when I use native FTP on my Windows PC I use the following PUT statement and this works fine:
put "C:\Data\Edison\14022020.xml" "'CG061.SMD935'"
The second parameter in command PUT is a new file name (not a folder)
you can write
and FTP utility uploads file with same name into current folder.
Thus, you have to upload you file to current folder and rename it.
Look at my example:
CatID=INTEGER|1163085779
ExternalName=STRING|"Task1329"
ID=INTEGER|-696558789
Name=STRING|"Upload and rename file"
ActionID=STRING|"A_FTP_LOGON"
Name=STRING|"FTP Log On"
anonymous=STRING|"1"
host=STRING|"localhost"
passive=STRING|"0"
port=STRING|"21"
proxykind=STRING|"0"
useproxy=STRING|"0"
username=STRING|"anonymous"
Name=STRING|"Set variable ""FILENAME"" with value ""C:\Data\Edison\14022020.xml"""
varname=STRING|"FILENAME"
varvalue=STRING|"C:\Data\Edison\14022020.xml"
Name=STRING|"Set variable ""NEWFILENAME"" with value ""CG061.SMD935"""
varname=STRING|"NEWFILENAME"
varvalue=STRING|"CG061.SMD935"
ActionID=STRING|"A_FTP_UPLOAD"
Name=STRING|"FTP Upload"
file=STRING|"D:\TEST\threads\Win32\Debug\uTread.dcu"
folder=STRING|"./"
ActionID=STRING|"A_FTP_DELETEFILE"
Name=STRING|"FTP Delete File"
file=STRING|"{newfilename}"
ActionID=STRING|"A_FTP_RENAMEFILE"
Name=STRING|"FTP Rename File"
file=STRING|"{ExtractFileName({filename})}"
newfile=STRING|"{NewFilename}"
