Auto-move file to category folders
No. It can be any string. This string is a some indicator.
See task below. This task extracts two lines after string RoboTask Renaming Begin from any text file.
;* RoboTask Task file *
;* Do not edit!       *
CatID=INTEGER|850444931
ExternalName=STRING|"Task319"
ID=INTEGER|233724025
Name=STRING|"Extract Names For renaming"
Action14=FOLDER
Action15=FOLDER
Action16=FOLDER
Action17=FOLDER
Action18=FOLDER
Action19=FOLDER
Action20=FOLDER
Action21=FOLDER
Action22=FOLDER
Name=STRING|"Set variable ""FILENAME_NUM"" with value ""0"""
varname=STRING|"FILENAME_NUM"
varvalue=STRING|"0"
type=STRING|"1"
value1=STRING|"{FileName_num}"
value2=STRING|"2"
Name=STRING|"Set variable ""NEW_FILENAME"" with value ""{txt_line}"""
varname=STRING|"NEW_FILENAME"
varvalue=STRING|"{txt_line}"
Name=STRING|"Break"
[Actions\Action14]
[Actions\Action14\Params]
operator=STRING|"6"
value1=STRING|"RoboTask Renaming Begin"
value2=STRING|"{txt_line}"
[Actions\Action15]
Name=STRING|"Set variable ""FILENAME_NUM"" with value ""1"""
[Actions\Action15\Params]
varvalue=STRING|"1"
[Actions\Action16]
ActionID=STRING|"A_LOOP_CONTINUE"
Name=STRING|"Continue"
[Actions\Action17]
[Actions\Action18]
[Actions\Action19]
Name=STRING|"Show ""Original name: {original_filename}"""
[Actions\Action19\Params]
msg0=STRING|"Original name: {original_filename}"
msg1=STRING|"New name: {new_filename}"
msgcount=STRING|"2"
Name=STRING|"Set variable ""ORIGINAL_FILENAME"" with value """""
varname=STRING|"ORIGINAL_FILENAME"
[Actions\Action20]
Name=STRING|"Remove variable ""NEW_FILENAME"""
[Actions\Action20\Params]
[Actions\Action21]
Name=STRING|"Remove variable ""ORIGINAL_FILENAME"""
[Actions\Action21\Params]
[Actions\Action22]
Name=STRING|"Remove variable ""FILENAME_NUM"""
[Actions\Action22\Params]
Name=STRING|"Set variable ""NEW_FILENAME"" with value """""
Name=STRING|"Text Loop"
destvar=STRING|"TXT_LINE"
file=STRING|"C:\sometext.txt"
linecount=STRING|"0"
sourcetext=STRING|"0"
type=STRING|"1"
value2=STRING|"1"
Name=STRING|"Set variable ""ORIGINAL_FILENAME"" with value ""{txt_line}"""
Name=STRING|"Increment variable ""FileName_Num"""
incement=STRING|"1"
vaiable=STRING|"FileName_Num"
Prem
Post by Prem »
Would it be possible that you suggest a basic script for checking the filename? So the task should be "check if string abc is part of a file in folder c:\filecheck" Or do you suggest that I look in Basic scripting forums?
Since Robotask has a Basic plugin, are there simple examples available for using this plugin?
Yes, installation program of Basic plugin contains a few examples of tasks with basic script.
Also basic plugin have complete help file about basic language.
