Connection closed gracefully
Re: Connection closed gracefully
How were you able to setup the gmail smtp (or what are your settings)?
What is the problem?
See screenshot below. It works.
marcolobaido
Post by marcolobaido »
Hi shbigdon, I use libero mail, not gmail. However I found the parameters in internet...
for you I found this:
http://email.about.com/od/accessinggmai ... ttings.htm
marcolobaido
Yesterday I started the task adding 1 minute between every mail...it stops after few mails. I used the new error variable and I added a "if then" command: when the error is "Connection Closed Gracefully" start a new task.
This task opens Google chrome ----> libero mail ----> and sends the mail by browser. In this way I can send the mail.
Is it possible that robotask can be limited by firewall and/or antivirus?
P.S. Those new error variables have been a good idea ;)
This is the server limitation. I'm sure
You can send email messages from web interface.
But SMTP connection has some restriction.
This is common spam protection of SMTP server.
