- Site Admin
Post
by Oleg »
See my folder structure:
- folderstruct.png (44.78 KiB) Viewed 19640 times
The task makes the loop in the folder
D:\Temp\images with subfolders (see step #5)
This task renames all files in subfolders with your rule.
Now this folder with subfolders such:
Volume in drive D is old_system
Volume Serial Number is CC50-B66A
Directory of D:\Temp\images
25.07.2014 15:48 <DIR> .
25.07.2014 15:48 <DIR> ..
25.07.2014 15:48 0 111
25.07.2014 15:43 <DIR> 18658-266.10.288
25.07.2014 15:43 <DIR> 18765-266.10.288
25.07.2014 15:43 <DIR> 18765-266.10.300
25.07.2014 15:06 <DIR> 18765-266.10.301
1 File(s) 0 bytes
Directory of D:\Temp\images\18658-266.10.288
25.07.2014 15:43 <DIR> .
25.07.2014 15:43 <DIR> ..
25.07.2014 15:44 <DIR> images2d
0 File(s) 0 bytes
Directory of D:\Temp\images\18658-266.10.288\images2d
25.07.2014 15:44 <DIR> .
25.07.2014 15:44 <DIR> ..
25.07.2014 13:15 0 18658-266.10.288-0001.jpg
25.07.2014 13:15 0 18658-266.10.288-0002.jpg
25.07.2014 13:15 0 18658-266.10.288-0003.jpg
25.07.2014 13:15 0 18658-266.10.288-0004.jpg
25.07.2014 13:15 0 18658-266.10.288-0005.jpg
5 File(s) 0 bytes
Directory of D:\Temp\images\18765-266.10.288
0 File(s) 0 bytes
Directory of D:\Temp\images\18765-266.10.288\images2d
25.07.2014 13:15 0 18765-266.10.288-0001.jpg
25.07.2014 13:15 0 18765-266.10.288-0002.jpg
25.07.2014 13:15 0 18765-266.10.288-0003.jpg
25.07.2014 13:15 0 18765-266.10.288-0004.jpg
25.07.2014 13:15 0 18765-266.10.288-0005.jpg
5 File(s) 0 bytes
Directory of D:\Temp\images\18765-266.10.300
0 File(s) 0 bytes
Directory of D:\Temp\images\18765-266.10.300\images2d
25.07.2014 13:15 0 18765-266.10.300-0001.jpg
25.07.2014 13:15 0 18765-266.10.300-0002.jpg
25.07.2014 13:15 0 18765-266.10.300-0003.jpg
25.07.2014 13:15 0 18765-266.10.300-0004.jpg
25.07.2014 13:15 0 18765-266.10.300-0005.jpg
5 File(s) 0 bytes
Directory of D:\Temp\images\18765-266.10.301
25.07.2014 15:06 <DIR> .
25.07.2014 15:06 <DIR> ..
0 File(s) 0 bytes
Directory of D:\Temp\images\18765-266.10.301\images2d
25.07.2014 13:15 0 18765-266.10.301-0001.jpg
25.07.2014 13:15 0 18765-266.10.301-0002.jpg
25.07.2014 13:15 0 18765-266.10.301-0003.jpg
25.07.2014 13:15 0 18765-266.10.301-0004.jpg
25.07.2014 13:15 0 18765-266.10.301-0005.jpg
5 File(s) 0 bytes
rice1973
Post
by rice1973 »
New "litle problem"
The subfolder in C:\3dmap\18765-266.10.300 are
images
images2d
thumbnails
They all have content. Only the images in the folder images2d have to be renamed.
I tried a few solutions in line 6 ( {ExtractFileName({ExtractFilePath({ExtractFilePath({FileName})})})} )
But i can't get it working properly.
Robotask rules!
rice1973
Post
by rice1973 »
Hi Oleg,
Any solution? I am stuck now...
Robotask rules!
- Site Admin
Post
by Oleg »
See the task below:
CatID=INTEGER|317955339
ExternalName=STRING|"Task372"
ID=INTEGER|1259557504
Name=STRING|"Rename files (only images2d)"
Action14=FOLDER
Action15=FOLDER
Name=STRING|"Create local variable ""FILENAME"" with value """""
varname=STRING|"FILENAME"
Name=STRING|"Set variable ""FILE"" with value ""{ExtractFileName({FileName})}"""
varname=STRING|"FILE"
varvalue=STRING|"{ExtractFileName({FileName})}"
Name=STRING|"STR Replace"
mode=STRING|"0"
replacement=STRING|"{folder}-"
source=STRING|"{file}"
substring=STRING|"img_"
variable=STRING|"NewFile"
Enabled=INTEGER|0
Name=STRING|"Show ""{FileName}"""
[Actions\Action12\Params]
msg0=STRING|"{FileName}"
msg1=STRING|"{File}"
msg2=STRING|"{Folder}"
msg3=STRING|"{NewFile}"
msgcount=STRING|"4"
Name=STRING|"Rename File"
[Actions\Action13\Params]
file0=STRING|"{FileName}"
ifexists=STRING|"1"
mask=STRING|"{NewFile}"
subdirs=STRING|"0"
[Actions\Action14]
[Actions\Action15]
Name=STRING|"Create local variable ""FILE"" with value """""
Name=STRING|"Create local variable ""FOLDER"" with value """""
varname=STRING|"FOLDER"
Name=STRING|"Create local variable ""NEWFILE"" with value """""
varname=STRING|"NEWFILE"
Name=STRING|"Create local variable ""PARENT"" with value """""
varname=STRING|"PARENT"
Name=STRING|"File Loop"
date1=STRING|"20140725"
date2=STRING|"20140725"
destvar=STRING|"FILENAME"
DuringMinutes=STRING|"1"
file0=STRING|"d:\temp\images\*.jpg"
searchkind=STRING|"0"
sort=STRING|"0"
sortby=STRING|"0"
sortorder=STRING|"0"
subdirs=STRING|"1"
timesize=STRING|"0"
Name=STRING|"Set variable ""PARENT"" with value ""{ExtractFileName({ExtractFilePath({FileName})})}"""
varvalue=STRING|"{ExtractFileName({ExtractFilePath({FileName})})}"
value1=STRING|"{parent}"
value2=STRING|"images2d"
Name=STRING|"Set variable ""FOLDER"" with value ""{ExtractFileName({ExtractFilePath({ExtractFilePath..."""
varvalue=STRING|"{ExtractFileName({ExtractFilePath({ExtractFilePath({FileName})})})}"
I added calculation of parent folder of the file (step #7) and the condition (step #8)
I tested it. It works.
rice1973
Post
by rice1973 »
Thanks!
Robotask rules!
